Hi bro
1.you can change to 150cc fz150i/vixion bore kit
2. each mechanic have different style of porting, if you have budget you can buy the aftermarket big heads
3.i suggest to buy big carb instead,
4. use aftermarket exhaust, you can use existing intake manifold
5. sprocket is trial and error. try all the combinations to check which one fits you
6.any cdi thats designed for sniper is ok. i use rextor cdi
Hi bro traxxas-modifier..
I want to ask about cdi rextor..
how we decide, how many degree we use with rextor, is it advance or retard??
what is the best suited curve for my bike?
my speck:
- vixion block
- porting polished stock head
- cld vanadium spring valve
- TDR pe28 adjustable needle in the middle, pj/mj 40/115
- WRD intake
- ferrox open air filter
- uni filter on engine breather hose
- coil protec ground strap
- denso iu24
- R9 new mugelo exhaust
- rextor cdi stock curve with accu powered
