150cc DIASIL, 178 cc and 188 cc SPECIAL BOREUP KITS
koreano
HELLO ALL, the BONUS TK VALVE, XP COIL is extended til Dec 27th, 2008 after that it goes normal again.. with various surprise bonus.. thank u
Hi BroHaen,,where are you now???I would like to buy a TK valve spring to you,,hope you will visit this forum again,,,,:rolleyes:
koreano
still here... :)
Hello Bro,,,i thought you left this forum,,,what are the new products or new updates regarding for our BIKE,,is TK valvespring are available right now???her in Phils.where hunting that kind of spring!!!Bcoz other forumers uses that spring says that its great & uncomparable,,,pls,,,bro give us up dates & share to us,,,hehehehe!!!!!tnx...
SPEED RACER
bro HAEN
if i use UMA 62mm ceramic coated cylinder shave .5mm & 22/19 head with faito turbo cams it is safe for daily use? what well be my HP and compression? tnx...
haen
@Speed : i think you put too much compression by shaving it.. except if you create a 7 or 9 degree squish pad on the cylinder head matching the 62 bore diameter.. using turbo cam usually with 28 mm carb resulted in lower peak rpm power and 19-20 hp power..
SPEED RACER
tnx. bro haen for your reply...
DeViLsToRm
Sir haen what can u say if i remove base gasket on a vixion kit with stage 1 cam(1mm lift) would i need to do pocket valve on stock vixion kit piston??any advice about it?
