150cc DIASIL, 178 cc and 188 cc SPECIAL BOREUP KITS
Mizpeh
Sir could you PM me the price and the complete list of the 2 package of this Vixion kit. I am from Philippines. Thanks you very much.
kurarensu
sorri bro,
may i know whats e size of my piston ah? n the brand of the camshaft tat i got frm u? thx.. my mech wanna know
yoshimura sniper
dongskie20 said:
special tuned vixion kit installed,
@bro haen
bro is that the right position of the piston? the mark that you said is in the lower portion which is the exhaust part.
bro post more pics/ for info.TIA
haen
AIS = Air Induction System.. using reed valve to inject fresh air into exhaust port to reduce pollution.. it's that UFO like stuff on the top of the cylinder head cover..
syfull
looks like u also moded your airbox too bro...hmmm....how do u fit the carb to the air box?n do u still use the original stock TPS after using this carb?thanx bro....
haen
it fits the stock air box.. just use a tuner drill to shape the hole.. i dont use TPS anymore.. really big difference using 28 mm compared to stock carb.. especially with big valve head and the block..
syfull
if the tps is removed,what happen to the warning light(u know,the red light indicator that blinks whenever we start our bike)?will it continue to blink?n how do u compensate with this matter?n how do u know if the engine is overheating or any other problem without the warning light?thanks...mmm btw,could u please pm me the pwk28 mm carb(including shipping to my place)?thanx again
dongskie20
@ bro haen
i really like this PWK carb,,is this compatible to my bike?? im not using the big valve only your vixion kit. pls reply to msg regarding this item.
haen
@syfull : easy, just take off the TPS sensor from the stock carb, connect it to the socket, and turn the potensiometer on the sensor until the warning light is off, u can use a small pin, after that, use a cellulose tape or anything to fix it on that position, the engine/water sensor is not affected by this, in fact, using a 28 mm carb with the vixion block cools the engine more.. due to increased gas volume..
@dongskie : any carb would fit, just need a little creativity.. this mix so far has been tested by me and provide good results.. :)
haen
PS : using PWK with this kit u won't have time to think.. because ur bike is faster than ur mind in accel :)
