sixty-thirty
Dose vixion and byson have the same piston ?
150cc Upgrade Notes Part One
Part One contains the necessary item and short description for upgrading the engine capacity.
Necessity item #1
Cylinder Block
Yamaha FZ150 150cc 57mm Complete Cylinder Bore Kit
- Cylinder Block
- Piston
- Piston Rings
- Upper Gasket
- Lower Gasket
- Wrist Pin 14mm
Necessity item #2
Camshaft
The camshaft is probably the single most important component when it comes to determining the power characteristics of the engine.
Necessity item #3
- *Yamaha FZ150 Original Camshaft - Stock Electric Starter Useable, Low Profile Characteristics.
Suggested (0.10mm Intake & 0.15mm Exhaust For Valve Clearance)- *CMS Camshaft – Balance On Review & Comments. Good Acceleration & Top End. (need confirmation on decompression slot info)
Suggested (0.10mm Intake & 0.15mm Exhaust For Valve Clearance)- Kawahara Black Cam with decompression Pin. Stock Electric Starter Useable.
Suggested (0.06mm Intake And 0.08mm Exhaust For Valve Clearance)- CMS Camshaft (T) – With Decompression Slot, Compatible With Stock Decompression Pin. Stock Electric Starter Useable.
Suggested (need more info & update on this camshaft)
Valve Spring
Objective - For higher RPM support & to prevent valve float.
- Yamaha FZ150 Original OEM Valve Spring. RPM Support Max at 12500rpm.
- CMS Valve Spring Or Any Other Aftermarket Valve Spring That Support Higher RPM.
Necessity item #4
Carburetor
Carburetor Mikuni VM22 (Stock Carburetor)
Mikuni VM22 rejet Size, Main Jet Range #110* - 115 & Pilot Jet #22.5
(Stock Main Jet #105 & Pilot Jet #20.0)
Main Jet Upgrade Size Is Available In #110, 115, 120 & 125
Pilot Jet Upgrade Size Comes In #22.5 & 25.0
*Notes/Tips: If You Increase the piston Size By 1mm, You Also Need To Increase The Size Of Main Jet By One Size.
(Example: Standard = 100 > Increase To 101). Use the closes jetting size available.
Necessity item #5
Capacitor Discharge Ignition (CDI)
Stock CDI is useable.
Stock CDI With TPS Degree Adjustment 9600 Rpm Max (Optional)
Stock Spring Valve Support 10000 Rpm Max.
To Adjust TPS Degree:
1. Set Idle Rpm To 1300-1500 RPM.
2. Set Digital Avo To Dc Voltmeter, Connect (+) To Yellow, (-) To Black-Blue Wire.
3. Adjust Your TPS Position By Loosen Its Nut To Get Avo Value Between 0.63-0.73V
Aftermarket Racing CDI
Recommended Setting at 11000 RPM, Max redline at 12000 RPM (For Durability & Daily Usage). The extra boost provide more higher top end for quick overtaking big and heavy vehicles on the highways.
- BRT Smart Click CDI
- Apido Racing CDI
- Rextor Racing CDI
- Any Other Aftermarket CDI.
Necessity item #6
Exhaust System
Stock exhaust modification, front manifold replace with 26mm. 3 section of exhaust filter cage removed.
Exhaust mods for 26mm front manifold![]()
Exhaust mods for 28mm front manifold![]()
The above image is just to get the basic idea on how to modified the stock exhaust for better air flow from the combustion chamber removing air restriction through the exhaust chamber outlet.
Other alternative is to get an a ready made aftermarket exhaust system installed or have it custom made by a qualified individuals/exhaust shops.
*Notes: Cylinder Upgrade from 54mm stock to 57mm & above is advisable not more than 30mm on front manifold. Use Gas welding only.
Necessity item #7
Air Filter
Change to an aftermarket air filter to make the carburetor breath easier, better air flow.
*Notes: Stock air filter cover can be altered like the K&N air filter in the above picture or totally remove the air filter cover.
Necessity item #8
Final Drive Ratio
Wheels / Tyre / Sprocket Combination Suggestion
70/90 front 80/90 rear. Sprocket 15/37 – 15/36
80/90 front 90/90 rear. - Sprocket 15/37 15/36 16/39*
80/80 front 90/80 rear. - Sprocket 15/36
90/80 front 100/70 rear. - Sprocket (need more info & update)
Preference for: yamaha lc135 shark block racing set fz150 x1r racing head
150cc Upgrade Notes Part Two
Part Two contains extra additional notes on item or accessories that we can use to gain more performance and optimizing setting.
Additional performance item #1
Ignition Coil
Ignition systems do one thing, deliver a spark of several thousand volts to the spark plugs at exactly the right time from a six- or 12-volt battery.
Yamaha Yz125 Ignition Coil.
Part Number: 4SS-82310-00
Part combination withAftermarket CDI & NGK Iridium Spark Plug.
*Notes: Air fuel mixture is recommended to set a little bit more rich than normal.
Additional performance item #2
Clutch System
6 Spring clutch housing with stiffer clutch spring is used to gain more grip pressure on the clutch plate for quicker respond on gear shift and faster acceleration.
Using these 6 spring clutch housing with stiffer clutch spring will make gear shifting upward or downward a lot harder to press and the clutch friction plate would be exhausted quicker. It is recommended to use the stock oem clutch spring with these clutch housing.
*Notes: For durability it is recommended to use the stock clutch housing, alternatively we can add stiffer clutch spring for more grip & clutch pressure.
Additional performance item #3
Carburetor
These are some of the jetting size used & shared by other with 57mm cylinder kit on different carburetor size collected on the net. This is a reference to have an idea where to start from, result may vary on individual setup.
Mikuni VM26 Round Carb
Main Jet #155
Pilot Jet #20
Mikuni TM26mm Flatslide
Main jet #102.5
Pilot jet #30
UMA Racing 28mm
Keihin PE 28mm
Main Jet #110
Pilot Jet #38
Keihin PE 28mm
Main Jet #115
Pilot Jet #35
Keihin Pwk28 Japan
Main Jet #110
Pilot Jet #37
Necessity item #1
Cylinder Block
- Cylinder Block
- Piston
- Piston Rings
- Upper Gasket
- Lower Gasket
- Wrist Pin 14mm
Necessity item #2
Camshaft
Necessity item #3
Valve Spring
Necessity item #4
Carburetor
Necessity item #5
- Apido Racing CDI
- Rextor Racing CDI
Necessity item #6
Exhaust System
Necessity item #7
Air Filter
Necessity item #8
Final Drive Ratio
Ignition Coil
Clutch System
Carburetor
Main Jet #155
Pilot Jet #20
Main jet #102.5
Pilot jet #30
UMA Racing 28mm
Keihin PE 28mm
Main Jet #110
Pilot Jet #38
Keihin PE 28mm
Main Jet #115
Pilot Jet #35
Keihin Pwk28 Japan
Main Jet #110
Pilot Jet #37
