15T/44T 415 chain sss
maxado
sir ano po kaya dapt kong gawin sa sprocket combi ko....madali masagad ang 1rst to 4th gear....kailngan ko ba mag bawas sa harap sa likod...stock engine pa po snipee ko and nob1 pipe yon lang po .......
maxado
ah pang track poba yan? ano kaya ang best mag 14T ako or mag 41T ako......meron po kaya pwede maka swap dyan sa 44 ko to 41?
marcusfilter
just do the math sir...
44 Divided by 15 = 2.93
2.93 will be your gear ratio. The higher the ratio, more accelaration you will be getting for your bike, but you will sacrifice your top speed.
Tyre size must be take into consideration as well
- Since you have a stock engine, IMHO best combi for City and Long drive is 15 40 with 90/80-17 front and rear tyre
15 40 will be giving you a 2.66 ratio
HTH
Ride Safe
maxado
Thank you for the useful info sir marcus.....i will change my rear sprocket to 40T
im using 70/80 front and 80/80 rear....
