Mga bro, Good luck, I'm prefer to be a fan of this event. Please be remind ha for the basic 1. Braking- Emergency stops are common in the field of moto racing. You have to be conscious of what you're doing et al braking. Just concentrate and with coordination in using both brakes. 2. Counter-steering- this is difficult. Only thing you should remember- the rule is "like follows like". If u'r going right then its your right hand that should be doing the work. Constant practice makes it perfect. 3. Cornering- you have to practice accurate calculations in a matter of seconds. Learn the degree of which you're required to turn to the corner and the necessary speed and gear you should employ when doing so. Braking must be employed before you access the corner. You need complete confidence in yourself. Confidence will teach you to trust your insticts- know when its the right time to turn. and 4. Focus your vision way out front.
