200cc - Which Would You Choose
HKholic
For racing, I would agree. When trying to squeeze every ounce of performance to oust your competition, then I would balance the crank. But for a commuter/play bike I wouldn't. I think you'll find the majority of members here with big bores are using them quite happily on the stock "unbalanced" crank. Just my 2 cents. ;)
TryX
I thought only if we change crankshaft bearing than only need to balance the crankshaft?? Enlighten me please.
SPEED RACER
uy paps miss you muah tsup hahha...
either of the two....stock stroke balanced crankshaft or with with 3mm stroker pin then balanced crankshaft with lighten piston....yummyyyy
me bro i prefer dynamic balance crankshaft ( its depend on what mode than in our bike ).
alx.cruz
another thing about a cheater engine (with short conrod) is that its cylinder wall doesnt last that long... this is due to more stress given on the cylinder wall because of the conrods angle against the piston to the cylinder wall...
TryX
Engine don't last very long too if jack rod too much. (Too much compression...) Unless it was done with the right formula. Not all foreman is good in this. So most important need a good foreman to do this kinda jobs. Monitoring compression ratio is important if want to jack rod, because you don't want to make your engine explode by over doing it.
blackknightrealms
ok my question is this, so we can segregate what should and what shouldn't be for 200 cc.
for commuter type mc on this type of setup. what usually your common setup to arrived to this power. i believe the issue will be the following for mechanics to decide what to do.
1. Owner has limited budget. what setup did you do?(parts to be replace or other needed action)
2.Owner has good budget.same "Q".
3.Owner has unlimited option. same "Q".
for circuit racing.( i know know it depends on the circuit but share us you setup)
for drag racing.
Can we elaborate which part to be avoided that give us problem, conflict or need some additional off the box modification.
how long usually this setup last.
what are the things needed always to give attention to when you have this kind of setup. like check the oil, carb or any thing that will indicate incoming problems.
thank you and hope this will give us newbie understanding how does 135cc became 200cc and how our master here setup their mc or their friends.safe ride!!
docgabby
define limited budget?
define good budget?
you can have unlimited options yet limited budget or good budget. option is just a thought..its free...:cool::confused::mad::(
blackknightrealms
define good budget?
limited budget..what usual request does some people ought to say when want to upgrades their speed. first usually will be replacement of rcdi, sprockets,etc. lets talk about engine parts. maybe some people here already done this for many times.so in your experience what is a usual upgrade you do if you to do a limited budget.whats will the first thing will come to mind after they already upgraded from external upgrade to engine upgrade.like preparation for a big one just to give him an idea what should be.
As for the good budget.already chosen parts and already there. we do have a good and bad parts combination.maybe they come to the point they choose different part but to your taste it will not work well. you suggest something else from your own experience. this will come to play now.
some mechanic tend to experiment on different approach, logic and experience. so maybe by this way you can tell us newbie that playing cheap is not a good idea. but play well and you will get what you want till your heart pumps out. I know some secret should be kept personal as trade secret.you don't need to that.partial idea will help a lot and maybe some of the master here can fill up the gaps.thanks and safe ride everyone.
TryX
Well from my experience the most basic parts cheapest way that give big bang on the performance is usually the replacement of:
Tight Budget Setup:
1. Bigger Engine Block
2. Open exhaust
3. Big carburetor
4. Lighter and New sprocket setup
5. Some minor porting on the intake and exhaust hole.
This is basic that what u need to get the most power out of your machine. CDI and Jack rod is a more higher standard if you got more budget.
blackknightrealms
Tight Budget Setup:
2. Open exhaust
3. Big carburetor
ok good.where going somewhere now. :angel:
TryX
If you got more budget than u can add up some of the few thing to the above spec.
1. RCDI
2. Harder Valve Spring
3. Big Head Valve
4. Jack Rod (Not really necessary.. Unless you playing drag.. Than only you need those fast power delivery)
5. High Camshaft (Give you different powerband)
docgabby
Tight Budget Setup:
2. Open exhaust
3. Big carburetor
wow this is tight budget???
1. vixion kit---6k to 8k depending on the supplier.
2. open exhaust---4k to 8k depending on brand.
3. big carburetor---2k to 8k depending on the brand.
4. lighter and new sprocket setup--500 to 2k above depending on the brand.
5. porting---not less than 2k including labor to remove head.
your talking about not less than 10k!! dats a tight budget???
