200cc - Which Would You Choose
TryX
wow this is tight budget???
1. vixion kit---6k to 8k depending on the supplier.
2. open exhaust---4k to 8k depending on brand.
3. big carburetor---2k to 8k depending on the brand.
4. lighter and new sprocket setup--500 to 2k above depending on the brand.
5. porting---not less than 2k including labor to remove head.
your talking about not less than 10k!! dats a tight budget???
Than if not change what? Change big bikes? There so many cheaper block out there why must use Vixion block? Maybe jack rod is cheaper? Or change CDI? Add howmany horsepower? If you have something better in your mind, why not say it out??? No need to ask me >>> "wow this is tight budget???" "your talking about not less than 10k!! dats a tight budget???" Just give your idea share with us. I thought you a veteran? Or im wrong? LOL
alx.cruz
It seems to me that we are getting way out of topic here...
I think the question of the TS is regardless of the budget, so we need not to talk about that...
just my two cents...
going back to the topic...
asides from the choices given by the TS, is there other way to build a 200cc sniper engine?
TryX
Yar you are right. Here is about sharing suggestions, not critics other people that trying to give suggestions. If he so pro why not enlighten us with his idea?? And not asking us the foolish questions....(ETC: "your talking about not less than 10k!! dats a tight budget???")
docgabby
most sniper owners don't have that much money to spend. you are talking about the average joe earning just enough. mods dont go cheap. the mods you mentioned as far as i am concerned are not for someone on a tight budget but for somebody serious. and my question aint foolish. i may be a general surgeon but 10k aint easy to earn!! if you are serious about modifying your lc, you should set your goal in what you want to achieve. careful planning and not hap hazard buying of parts that most do. i have 210cc daily driver setup differently and a 200cc sniper for the unified drag rules limited displacement category.to achieve the desired mods it is not advisable to buy this part then that part then change again. i plan the parts that i think would suit most my needs. case in example. i need a close ratio for my 200cc sniper drag. i had to buy a whole set from malaysia worth RM550 plus freight and taxes that would be an additonal RM150 to RM200. i would only be using the first gear from that set! the rest are paper weight. they wouldn't sell me just the gear i needed! then the third gear i needed is custom made in indonesia and that cost usd110! then the 4th gear is an aftermarket. thats the close transmission alone for the sniper drag. for the 210cc daily driver, the transmission is also set up differently. again i had to buy two sets just to get the 2nd gear of one set and 3rd gear of the other set, the rest are dead paper weights. some ask me why the need to buy two sets. like i said it depends on the setup i am after. some dont have the patience of looking for the parts they just keep on buying aftermarkets here and there, if not satisfied they buy again. then that person is not on a tight budget. when i buy my parts i just stack them on the shelve. go over my checklist then set my sights on the next mods i need. when the list is complete then is the only time i put them in all together. sometimes it takes 6 months to a year to complete that lists. because i browse in forums like this looking at feedbacks that will make choose wisely. so it will be money well spent. if in case i buy one part then find out later there is a better one, i sell that former as part never used. because i am not quick to buy then install. its only and only when i complete my lists will i install them all. its much cheaper on labor costs! my concept of a tight budget is what are all the parts i can buy with that limited budget like a package deal. i dont do that or recommend that. if i had 10k now what cdi can i buy for that amount? after careful choosing, buy the part then keep it. after 2-3 months i again was able to save another 10k, what displacement am i planning to increase my engine to? research again. buy then put aside. once i have completed the list then its the only time i have them installed as one. thats wise buying. i dont feel the so called tight budget because it was money well spent.
blackknightrealms
actually this are good exchange of ideas. but we have to respect others response. the purpose of this thread to let us know how and what to expect when we decide to upgrade our engine.but also will give us idea where is the possible shortest selection of parts should be chosen since some of us here already has an experience on doing this upgrades. so guys keep the idea coming. thanks for all the inputs you all give up.
TryX
Your mode is very extreme. I have a checklist over 6 months already still got some minor problem need to be solve before i making 180cc Sniper with big head Valves.. I done some minor gearing changes by changing the 4th gear to a smaller teeth to reduce the gear ratio, other gear i never touch it.. Third gear is hard to find because no any aftermarket company producing it unless if you are in the Cubprix racing series which they have to use specific gear box for racing purpose and they are not aloud to partially change the gear setup in they bikes. And also third gear is the most powerful gear in the bike usually we wont change that one.. But first and second and fourth gear is more easy to find..
What i suggesting is just base from my experience. The cheapest way to get the juice out of the machine. If the owners really want to spend on they bikes and want the result. New Big Block, big Carbs, Open Pipe, Intake and exhaust minor port and polish and lighter sprocket is a must. If don't have this type of budget or you just add one or two things in it better don't modify because not much gain to the bikes... Well is cheap to be doing this in Malaysia. Find a second hand carbs and open pipe. Than get a new aftermarket 60mm steel bore. And new set of lighter sprockets will do. Maintenance is simple, check engine oil level each week make sure not much drastic oil is reducing but if you are more extreme long distance traveler than have to check each time u go for long distance travel. That all.
docgabby
Your mode is very extreme. I done some minor gearing changes by changing the 4th gear to a smaller teeth to reduce the gear ratio, other gear i never touch it.. Third gear is hard to find because no any aftermarket company producing it unless if you are in the Cubprix racing series which they have to use specific gear box for racing purpose and they are not aloud to partially change the gear setup in they bikes. And also third gear is the most powerful gear in the bike usually we wont change that one.. But first and second and fourth gear is more easy to find..
What i suggesting is just base from my experience. The cheapest way to get the juice out of the machine. If the owners really want to spend on they bikes and want the result. New Big Block, big Carbs, Open Pipe, Intake and exhaust minor port and polish and lighter sprocket is a must. If don't have this type of budget or you just add one or two things in it better don't modify because not much gain to the bikes... Well is cheap to be doing this in Malaysia. Find a for second hand carbs and open pipe. Than get a new aftermarket 60mm steel bore. And new set of lighter sprockets will do. Maintenance is simple, check engine oil level each week make sure not much drastic oil is reducing but if you are more extreme long distance traveler than have to check each time u go for long distance travel. That all.
unless you do wrenching your self then it would be cheap. most have to pay for overhauling. just changing the 4th gear to 21T or even 20T i wouldn't even recommend, if you change the fourth gear change the 1st gear too, it will give you a better close ratio. contrary to your belief, 3rd gear aint the most powerful one! i have chatted with several malaysian modifiers, all of them change the third gear! its either you want your transmission close to each other or farther apart. to touch the transmission ratio would take alot of thought. take for example an aftermarket transmission kit sold in thailand with the following ratio- g1-13/31, g2- 17/29, g3- 22, g 4- 21. dont you know that this kit is two types of sets in one!!! the gear 1-13/31 and 4-21 combined with stock g2 & g3 gives you a good close ratio transmission!!! gear 2-17/29, g 3- 22 combined with the stock g1 & g4 gives you a good wide ratio transmission. that aint extreme modes but wise thinking. why would i buy just the 4th when i know it aint enough. i would rather save my money buying the complete set and choose the ratio (close or wide) i want and sell the rest! i save on labor and get the performance i want and sold the gears not used. overhauling here in the philippines costs not less than 1,500php for labor alone. the cheapest way to get juice out your machine is improve your driving technique and not improve your machine to compensate for a poor riding style. i have seen riders on stock machine ride rings around riders on heavily modified bikes in circuit races.
TryX
I not playing much with gear ratios coz im no good in it. I more prefer to play with the engine and setting parts. But the 1st gear and 4th gear ratios you suggest will be put in the considerations. Coz my fourth gear is 21 teeth. Cool input.
Btw, can you define what is paper weight?? isit you mean is too light? Material no good? or just that is not the ratio you want?
docgabby
the gears i dont use are on my office table used to hold down papers..hence paper weight or better yet weight put on papers to hold them down....table ornament...
blackknightrealms
its a common expression of naming things that you buy but will be useless in end so commonly prefer as paper weight because that's the nearest possible thing you can think other that putting in box and keep it .
so now lets put it this way. about the gearing ratios of inner engine.hence the later sniper has 4 gear only. so its really necessary to balance the ratio between gears to avoid shifting out always. to close or it would go overdrive. How about it we apply it to SMX who has 5 gear on 200 cc setup?i think that ratio will be good on this one since you have an extra gear for lessening the close ratio. are the gear available for the present sniper? which you block you prefer to be used either in long or cruising drive. which part should be replace to attain this upgrade without getting into problem. can anyone here define their parts list, how much they cost(if possible). So not only me but all who will read this thread will have a further sense of understanding of doing upgrade. after your upgrade. what problem you encounter during this testing and long term use. Apology if ask too much. But i would like a better understanding what are the pros and cons of doing this path.thanks for the response and hope some one other veteran join in the band!safe ride everyone!
docgabby
at the moment there is no available that i know of upgrade transmission for the new 5 speed. sir traxxas is i think is selling a 6 speed surplus trans that could be transplanted to the 5 speed centercase.
here is what www.gearingcommander.com says comparing the 4speed sniper vs 5speed sniper::cool::coffee::thumbsup::eek::rolleyes::D
4 speed: primary drive ratio-2.875. rear tire-80/90x17. @ 85oo rpm. final drive-15/39 (2.6)
gear 1-43.6kph.
gear 2-65.8
gear 3-91.2
gear 4-118.1
5 speed: primary drive ratio-3.042. rear tire-100/70x17. @ 8500 rpm. final drive-14/38 (2.71)
gear 1-39.2
gear 2-59.2
gear 3-77.7
gear 4-95.1
gear 5-106.8
the 5 speed (9.21 kW @ 8500 rpm) has more horsepower than the 4 speed (8.45 kW@8500).
this are factory specs.
alx.cruz
Maybe this will be a good component to add when building our 200cc Sniper...
they have claimed to have a 28hp engine with this installed together with Uma 62mm block, 34mm Carb and a good exhaust like Leo Vince...
I'm looking forward for this to arrive here in the Philippine shores...
UMA Super head
uma super head 1.jpguma super head 2.jpguma super head 3.jpguma super head 4.jpg
rowan
remember guys speed cost money
doc gabby talk here about 200cc whether you choose or not
if u want to keep ur budget tight then its up to you and keeping things cheap you will end up an easy breakable bike.
10k alone is not sufficient unless you are satisfied with it ..a lot of things to consider to match the power of your bike like 200cc
especially on your stock parts. maintenance cost will double also unless you dont care for your bike.
i have only 150 cc but 10k is not enough to be honest
we modify our bike we dont spend on mech ...buying parts alone cost much
modifying bike is unending .you want better performance you have to spend. if you dont want to spend then dont modify and keep ur bike stock.just dont get envy on other bike's speed.
back to topic
now what would i choose for 200cc bike ? which is which??
i prefer 3.5 jack up and 62mm uma bore
if you want to modify dont make budget cuts
thats my own opinion only guys
TryX
I got the feeling that UMA head is very big... Not suitable for normal machine that below 190cc... Need to be over 190cc to put that head on. I have been testing normal big bore like 60mm and 62mm using big head like 22/20 head but when i fight with machine with the same bore but using stock head. The Big head still loose to the small head bike... The power come not fast enough... Even big head is powerful but it take longer time before the power come.. Unless if the machine is jack rod than only i can can feel the not sinking power come pouring down to me.
alx.cruz
As I have read in Racing Boys FB page, it is for a 177cc engine...
as they have claimed, you will be achieving the 28hp with installing this head together with 62mm Uma Block, 34mm carb and a good exhaust...
they also said the valves is 25mm... they did not mentioned the size of the exhaust valve...
blackknightrealms
That's the reason im asking this question is i'm really interested to go first to 150cc or 180cc or just jump to 200cc specs. And i know when you want power it means you have money. If someone in here who can guide a proper parts selection and its price. then we can really see what how much to expect. so we can save a little for this mods. It's easy to mods if you know what are the parts to choose and only needed a good mechanics.
Some of us here already pass those trials and error thing. maybe can you spare us a short cut?:D . I have plan to upgrade my SMX in a year from now since i'm still outside philippines. and my MC is only 4300k ODO reading. hopefully my wife can push it above 8000k. But i am looking forward for a guide for parts selection.pros and cons. and besides what ever you post on this thread will help some us in near future.specially new parts are coming and technology improving. Thanks!
blackknightrealms
Interesting items. does this one really fit our sniper?
