2011 T135 review
hi guys
i was able to sit on 2011 T135 during the YamahaGP (sad to say not able to test ride it)
the first thing i noticed is its already bended handlebars much comfortable
compared to older versions.
ive talked to the yamaha guys they said, it can reach 130kph 3rd gear???
BHER
wow 130kph in 3rd gear ???
it is posible if engine is modified, but if it stock i don't think so
Blaster
There's only one way to find out...
Who's going to give it a spin? I'll do it as soon as I can on my MX
Stock then after Dr Trax does his work
Cheers!
SPEED RACER
i test the 2011 sniper mx 135 its my friend unit not mind
1st gear 45
2nd gear 80
3rd gear 100
4th gear 125
5th gear can't hit 130 stock sprocket 14/38
then we change the the whole sprocket combi 15/42 420 size made some mods like
REXTOR CDI
RACING CAMS
MTRT IGNITION COIL
MTRT VALVE SPRRING
modified the airbox
close AIS line
shave block by .5mm
SPS muffler thailand maid for sniper mx
28mm keihen carburator
4th gear 135
5th gear 145-150
sagad
1st gear 45
2nd gear 80
3rd gear 100
4th gear 125
5th gear can't hit 130 stock sprocket 15/39
REXTOR CDI
RACING CAMS
MTRT IGNITION COIL
MTRT VALVE SPRRING
modified the airbox
close AIS line
shave block by .5mm
4th gear 135
5th gear 145-150
145kph...i hope i can experience this someday..:cool:
4f7erx
1st gear 45
2nd gear 80
3rd gear 100
4th gear 125
REXTOR CDI
RACING CAMS
MTRT IGNITION COIL
MTRT VALVE SPRRING
modified the airbox
close AIS line
shave block by .5mm
4th gear 135
5th gear 145-150
bro are you sure about the accuracy of the speed ? well, if its true i might get new mx. i think stock sprocket is 15/38 for mx.
SPEED RACER
old model and mx have same sprocket combi, yes bro im sure, the problem of sniper & sniper mx is the top end power thats why we replace the rear sprocket with bigger one like 42 teeth to enhance the top end speed but we remove the decom pin & rocker.
Method21
it can achieve 130 on 3rd gear..if your displacement is 600cc w/a stock tranny;) or a modified engine with a 45/100 front rubbers:p
4f7erx
100-1o5 speed for 3rd gear is achievable but 130 on 3rd gear i don't think so, if that happen you need bigger piston & gear small sprocket combi..
wow ! i never tried my self, hmm... im choosing the MX or the fZ16 both this machine have a great comfort ride. i need to test my self of which is better performance. if that is true runnin' 130 (mx) on 3rd gear thats unbelievable for stock engine.
SPEED RACER
bro 130 on 3rd gear with stock engine, stock sprocket it's not true, 3rd gear can achieve only with stock engine & sprocket 90-105.
allanmx
3rd gear on my mx only reaches 90-100 kph equipt with ahm pipe and clutch spring. maybe it's because of my weight (80kg.) or my cdi that keeps on cutting my speed.hehe . stock sprocket of mx is 14/38.
blackknightrealms
pafs my mx are all stock. on my first try it gave me 100km/hr when my odo is around 1100+. but after change oil and filter on 1200 on my next try, it gave me 105( 3am in C5 so i have time to look on my Speed) and other time it gave me same reading, try to pump more but that's it. im 79kg that time( today im 75:D)
