2011 Yamaha T135 Transmission (5 Speed) vs Old 4 Speed
docgabby
doc gabby
few days ago ive seen a counter gear (in the machine shop) as shown exactly in your picture posted (right part)
its 26t, i dont know what motorcycle.
maybe its from wave,xrm as those bikes are common in our area.
basically it was just lying beside the lathe machine when i saw it,
i forgot to ask what motorcycle it came from.
wow!!! hope its the gear i have been looking for???
Tr3C3
This thread right here is the one im really looking for.. Lots of jargons for me as of now but I am more than eager to cope up and be an apprentice and be educated for all its worth and future learnings... More power to Sir Traxxas and DocGabby..and to all the brothers here... ROCK ON!!! :)
Kim G Linagatik
Doc at papz tatanong po sana ako po sa aking 2009 lc po 170cc lng po kc
Tatanong q sana kng pag add ko ng 5th pinion at gear sa old lc from new lc po
Magkakaroon po ba ako ng overdrive at pasok po ba sa tranny? Na canvas q na po materialS q
Around 10 magagastos q. shift cam shift forks at tsaka ang dalawang gear lamag po
Posible ba ma palitan q to at mag kaka overdrive ako?
boldstardex
Reminder: YOU ARE ON ENGLISH SPEAKING SECTION, Please post in ENGLISH!​
docgabby
by the way, what are the advantage and disadvantage of a 6 speed dok? is it better than 5 speed?
more gears to choose from the better. it lessens gaps or drop in rpm and speed in between gears. it allows the engine horsepower to work much easier.of course more gears more complicated, more gears heavier, more gears more shifts. just imagine pedaling a bicycle comparing a 4 speed to a 6 speed going uphill, sprint, or even flat. more gears affords you more versatility. just imagine lifting multiple dumbbell...lift 4 dumbbells one after the other....1kg, 5kg, 10 kg, 15kg..then lift 6 dumbbells....1kg, 3kg, 5kg, 8kg, 11kg, 15kg.....how would your body react to the different kinds of weight....
