60mm Bore On Stock Valves And Stock Cam
CLYDE
Is it possible to just change the stock bore to 60mm aftermarket borekit without changing the cams, carbs and valves. I dont want to use the kickstart so i want to retain the stock cam with decompression pin, I will just rejet the stock carbs to MJ110 and PJ25. BTW i already change the valve springs to vixion and is currently using racing cdi and race pipe. Will this setup be still safe and will not cause detonation due to high compression (using big bore but not changing to big valve head)?
xclickclickx
It will be perfectly fine not a problem
boogaks12
try to use nikasil pitbike or uma its better than steel bore..
mine using 62mm x-ray steel bore after 2 days of break in and hiting 120 kph it sounds plak plak plak...
other says gas is lean but i dont know the real problem but i think its overheated due to stock carburator...
back to stock...
its ok, however if you have a budget and really want to optimize its best to have bigvalves.
if u use stock cam, its best to use vixion cam, little bit higher than stock cam and still safe to use plugnplay.
dont forget jettings
boogaks12
Hey monster trax.. Do you have an experience bout on lhk rcams stage2?can i put it on my beloved vixion kit without valve pocketing?tnx 4 d answer my friend..:)
