its ok..but if u want true power go 4 the big valve...
most of my fren just install 60mm bore...but other part are stock..the meter keep knocking the 180 mark
Tnx Sir,60mm bore & big valve,nO need stroker pin..??..i think its nOt mAtch,mAybe it nEeds stroker pin to mAtch 60mm bore & big valve..
is it ok for tOuring/drag big valve & 60mm bore..??..nO pOssible negAtive mAtters 4 dAT mOds..??
