60mm borekit by TDR
tashrey_888
thanks bro ..... how much is it ? valve springs and the cam yypang? do you the address of the store and tel no.? im in bacolod city...tnx
marcusfilter
sorry bro...I will PM you the price...
atr-mc
doraemondizon said:
martian sabog
arnold sabog
Aray ko po! Bro may additional info ka pa ba? Kaka kuha ko lang nitong block na to, pero di ko naman nagagamit mc ko ng malayuan. Masamang balita to ah... :cry:
addison
So far my 60mm block is okay and also with my friend, 1st installation i have a problem on the gasket nag leak ang coolant patungong piston, so I re used the original gasket, cut namin para tama sa butas ng new block then apply thin layer of threbond after that no more problem, so far my top speed on 15/40 sproket with nanban cam also super imax 140 kasi yan lang ang kaya ko pero ang bike meron pang ibibilis.
addison
yy pang valve spring medyo ingat kayo dalawa na kaming naputulan, di naman sa naninira sa yypang but kailangan natin ipaalam din sa concern dealer or store ng yypang ang product nila ay medyo may kahinaan, what I need to bike I put it back my original valve spring nag add na lang ako ng washer 1.5 to 1.8 lang ang pupuwede over 1.8 tutukod na ang rocker arm.
big poppa
atr-mc said:
doraemondizon said:
martian sabog
arnold sabog
Bro tip lang.. pa check mo muna face ng block (bka nid reface) at gumamit ng orig head gasket yamaha (pang vixion or sniper) at palakihan na lang butas nito.
ako two months din gumagamit as in stock set lang.. pero nagkaproblema na lang nung mag pa high comp ko.. naka tatlong head gasket na ko (tdr 60, malay 58, stock sniper 54- dito nagtagal ang gasket). well dala na rin ng warping sa block ata dinala ko na sa machinist for lapping. One more thing need na rin palitan rings nito hehehe.. un mahirap hanapin hehehe, well at least nasubukan natin... :D
atr-mc
big poppa said:
[quote="atr-mc":2vfni3wr]
doraemondizon said:
martian sabog
arnold sabog
ako two months din gumagamit as in stock set lang.. pero nagkaproblema na lang nung mag pa high comp ko.. naka tatlong head gasket na ko (tdr 60, malay 58, stock sniper 54- dito nagtagal ang gasket). One more thing need na rin palitan rings nito hehehe.. un mahirap hanapin hehehe, well at least nasubukan natin... :D[/quote:2vfni3wr]
Thx Bro sa tips, ipapabasa ko nalang to sa mekaniko ko. Ako kasi siraniko... :oops:
interceptor
madami po kasi fake ng yy...
kaya ingat...
