7 AMP Battery
mingomz
"Hard starting" (Reason: Cams)
has anyone tried using 7amp battery. (ie battery of Raider 150r?)
By MF battery is still working (8mos old) but cannot do the job to start my bike.
Thanks
ice tried looking for a bigger battery back then, checking its dimensions..
then i realized the battery compartment area is too small for the bigger
amperage batteries.
if you guys know a smaller dimension battery with bigger amperage
let us know...
rowan
hi,,,my friend in banga using 2 batt, one is 4 amp and our stock 5amp, make it parallel connection.(all in all 9amp) wondering where did i put the other one ? inside his airbox. the other batt is quite smaller..it can fit inside the stock airbox.
mingomz
Up For this thread.
@ traxx
What cams are you using? do you also experience hard starting on your sniper?
thanks for info bro sacker,
now we know.
btw have you tried fitting the 7amps Motolite maintenance free?
@g-tomahawk
im using vixion cam.
im satisfied with my engine mods so theres no need for me to
use racing cams :)
this a nice idea bro! thanks for the info.
so far im ok with my 5amps battery.
moving the stock battery from top to aircleaner box will lower the central mass of the bike.
that will improve handling.
plus the old battery box will now become your UBOX!!!! :D
will try that bro :)
lets see if it will fit.
mingomz
Thanks for the replies
This is a nice idea. I will also try to put the battery in the airbox. :)
rowan
with out airbox is easier fit , with airbox u can fit 3 amp batt without hassle inside it
i rem from this tread also one forumer said best stabilizer for our bike is higher amp .:D
its d product of following all your tips here in t135. so far all set up with our bike all 3 of us (rowan , NOI.357 and frankie)were same and proud to say all came from t 135 forum tanx esp to traxx and other forumers. all we do is try and test what had been suggested here and see d best result.actually watever we got from here we suggest to our mechanic and he'll jst follow it and good thing it all works.
@traxx one of my friend use rextor by adding batt he said he got better performance
Jval Zkie
tips from traxx is tried and tested but beware once you got it you will be addicted to it:D
sorry for the OT:)
mingomz
what is the recommended resistor value if you go for a 7 amp battery?
One of my considerations is the koso digital guage.. too much amp might short it..since the power is direct from the battery.
sometimes I go beyond 13 volts is this ok? would that change once i change from a 5 amp battery to a 7amp battery?
thanks
zcbitik
nice idea.. can any one post a pic for small battery that will fit for the airbox? I don't have any idea what does it looks like :)
marcusfilter
I think the issue here is the starter motor and not the Battery
To explain this further
1- Stock Starter motor is designed to start an engine with 135cc displacement, stock cams or in short (No kalikot)
* To Start our bike with Modified engine with a high lift cams, the starter need to kick much harder because of the high compression.
Resolution: - Have your bike check, ipa LOCOMP mo
- Have your stock starter rewind to make it work with your high comp Cams
Advantages/Disadvantages of Rewind Starter( Logical thinking )
Advantages - Will start your bike easily if the only issue is high comp(other issue that will now start bike, not properly tuned....etc)
Disadvantages - If we are using stock or 5amp battery, pretty bump or almost near the end of its service....If you cant make it start from 3 to 4 times, 80% your battery is drained and you have to kick it to start
Anyways, Ampere is the Constant Current the flows through electricity while Voltage is the current/power needed to make something work.
Heard a lot of question regarding batteries...Why does my battery doesnt work? I already tested it with a Volt meter and it gives me a reading of 12.5volts...The answer is, the designed ampere for the said battery is weak already that's why anything that you will attach to the battery wont last or wont even work if it has a higher wattage....
HTH
ride safe
m00nraker
his using cms cams like mine.. the battery idea came from yoko hehehe.... so he try to get other opinion
mingomz
HTH
ride safe
Thanks pre for explaining.
So regardless if you have a higher ampere of battery this would not make any changes on how your bike will start right?
My bike can start "sometimes" using the electric starter, but most of the time not. like 1/10 chances. I guess my battery became weak so fast. It's only been only 7 mos. Before it used to start smoothly without any hassle despite that it's block and cams were modified.
I already found someone who can rewind the starter motor. Info came from Gerry. 850 bucks. near his place.
OT: most of the people who loves you are asking why you not reply on sms. Ü
very well said....anyway mings what brand of cams are you using? lift?
Like what paul said CMS cams. Performs really good. Bike starts really hard.
Yes, I would like to get other opinions from folks who have the same problem. Good thing I did not buy anything yet because I would like to get a lot of inputs before making a move.
