blackfly26
regarding if you have a back ride does your brake works??? thanks for sharing.
bro panget kasi pag cable gamitin natin eh, madalas di ganun ka reliable ung brake sa likod lalo na pag may back ride,,, try mo na lng ung set-up na ginawa ko kasi tested na un for goodhugaw said:papa
may idea po kayu regarding
cable brake sa drum brake
natin?....
opo sir putulin mo un tpos balik mo sa stock set-up ng sniper ntin... dun sa likod nung pinutlo na part,, kabit kayo braket,,, then turnilyo nyo isang rod papunta sa RS nyo...hugaw said:etong part na 2 ba ung
pinutol mo papa?
try ko po ha bka sa friday ko pa ma post ung pic kasi kakalasin ko pa ung pipe,,, pero gawin ko ASAP para aditional info na din... thankshugaw said:additional request papa
may close up pic kau ng
double nut dat is connected
to the bracket and RS brake
pedal?...and close up pic
po ng returned part ng
pedal with the welded
bracket...
TIA po..cnxa na, dami
ko request....
ok lang sau papa?red_is_karma said:try ko po ha bka sa friday ko pa ma post ung pic kasi kakalasin ko pa ung pipe,,, pero gawin ko ASAP para aditional info na din... thankshugaw said:additional request papa
bracket...
ko request....
actually there is no need to for an additional spring kasi dun sa stock brake pedal na puputulin, sa likod nun may spring attached to the chassis so kusa pa rin sya babalik,,, light nga lng tapak mo babalik kagad eh,,, it works very good,, and ung brake light gagana din kasi dun din nakakabit sa stock un,,, if you are in manila area pwede nyo makita personally ung bike ko para ma-testing nyo din,,, i'll post pictures na din asap,,, thanksewad said:very nice sir! ask ko lng po do i need to put spring don s nawelding n bracket?d b sya nastock up? i mean kusa n ba sya bumabalik? i think this is aplicable to all rear set.one more thing un brake light ba sir gumagana pa rin?
