Adding Up A Little Power And Speed
ilek
hey guys! would you mind giving me some tips or guide on how to improve acceleration and speed of my sniper classic. my current set up is, 15t/42t sprocket, yypang shorty pipe, 80/80 f 90/80 r mizzle tires and the rest is all stock.
im a little bit confused on which part should i upgrade first. i need simple mods for everyday use city driving and touring. ^^
with a limited budget which part should i upgrade first?
first make sure you replaced your Air Filter since you have an open pipe. Next stage...
1.) Yamaha Vixion Kit -150cc
2.) Vixion Valve Spring - Prep for Racing CDI
3.) Vixion Camshaft
4.) BigValves
5.) 26mm Carb
6.) No Shaving of head. Just port and polish intake and exhaust inlet/outlet.
7.) BRT Hyperband or Rextor CDI
8.) Get an expert Mechanic
You should be at around 18 HP with a reliable engine that would last for years.
Stockbore
for starter with minimum budget, any pair of the following will do
brt hyperband/dualband - 3200
vixion valve spring/ - 1600
uma/cms cam - 2100
28mm thailand PE keihin - 3000
ilek
is it ok to upgrade 1st the carb or the cams and valve spring? im having 2nd thoughts in rcdi a friend told me that it could break the engine or shorten its life.
Stockbore
depends on your driving style. just dont over rev too much and everything will be just fine.
if you drive like an addict pushing lower gears over the limit then problems might occur.
Stockbore
for 3 years i only installed cdi on my bike with 14x45 sprocket. i never had a problem with it. all went smooth
Paladin
If your goal is acceleration, the easiest you can do is to change to bigger carb and clutch spring.
jangbest
If you install RCDI alone Surely 100 % your engine will kabooomm...
Tandem to RCDI is Valve spring to avoid valve float.
Shorten your engine life it depends on how you maintain your bike and to your mechanic also.
Topkick
Be clear first, bro. Is it for racing purposes? I guess not because you mentioned SIMPLE MODS for EVERYDAY USE city riding and touring. In my own opinion, the simplest and basic upgrades suggested by others in this thread might do. Good luck, bro!
Topkick
Besides, there's no place for a full race motorbike in the busy streets and avenues here in the metro. Only in a race track. It's just going to get us killed. Sad to say.
