slm pagi semua
Cuma nk dapatkan lebih info dr otai2 lc di cni
1-apa bezanya dgn yg std ?
2-dr segi perfomance mcm mna ?
thank semua
Haha, I only understood 40% and that is not good enough.ENGLISH PLEASE..
i think no one has been tried using the ADVANCE TIMING GEAR. its pretty good if you get the right timing but very very very bad if you dont. so its better to use or not to replaced the stock.Haha, I only understood 40% and that is not good enough.
With slang and short Bahasa Malaysia abbreviation, it's like me
trying to understand slang in Tagalog ?
Will he come back to clarify himself or shy to champor with his Bahasa Ingeris ??
He's asking ...
With respect to Adjustable Timing Gear Lc135,
1- What difference as compared to standard cam timing gear ?
2 - In terms of performance - how ?
My question is: Can you get Adjustable Timing Gear for the LC135 ?
Has anyone or Mr Traxxas tested an Adjustable Timing Gear for the LC135 ?
My thoughts are it may be a waste of money & time installing an Adj Tim Gear
bcos the 135LC is a single cam engine.
Might as well get a Racing-Boy/Faito cam for the Road and Not for the Track.
Might be different if it's a DOHC engine. You could advance intake timing
by 3 degrees with the Adj Timing Gear to give it more torque at lower engine RPM.
Or tweak the Cam Timing to get more performance near the top engine rev.
My 2 cents worth.
We suggest you don't use ADVANCE TIMING GEAR - no point becausegood morning everyone
im so sorry because my english was very2 bad
im looking 4 advise or suggestion 4 those who already use adjustable timing gear 4 their lc bike
dont give me a theory result if u never use it
once again sorry 4 my bad english
New model lc135 v2 2012 auto clutchWe suggest you don't use ADVANCE TIMING GEAR - no point because
your LC135 is single camshaft and not Double Overhead Camshaft (DOHC).
Lu punya model LC bahru atau old style ? U nak track racing atau syiok2 naik
LC saja. Berapa RM u nak keluar?
Tak guna kalau ganti satu barang - buang duit saja.
Dalam post di situ tentu ada lain kawan yan sudah chari macam mana
nak tuning untok LC. Sila bacha post2 tu.
I suggest u modify main jet & pilot jet di Carburetor.
Tukar plug untok Denso Power Irridium.
Modify exhaust kasih angin keluar senang sikit.
Air filter tukar ka K &N.
salam nak tya...nak marking yg dkt head 2 mcm na ya..marking dkt tgh2 ka?Nk set timing gear nie sgt2 lah detail..nk kne marking btol2.jarak antara 1gigi ke 1gigi dh lbh kurang 9-10 degree..so nk dptkn advance/retard dlm 2-3 degree shje..klu combine ngan degree wheel maybe dpt setting yg sesuai
Hak ah...selari dgn garisan spoket timing chain dgn head...nak
sya pnya bang lari semata ke atas...tak leh mark selari ngn head...Hak ah...selari dgn garisan spoket timing chain dgn head...
Man klu marking xleh dpt tgh tu kena naikkn ke atas atas bwh. Motor dh jack 4mm marking lari la bro.Hak ah...selari dgn garisan spoket timing chain dgn head...
2 yg pelik x dpt mark timing cam selri ngn head..sya pnya mang lari semata..skg sya mark 1 mata ke bawah...Ingat jangan salah marking..
1lagi gigi gear kat crankshaft tu jangan cuba² alik..silap hari bulan jem saje blok nye..
Penah pomen saya buat 1 motor nie..owner buat ditempat lain..8 kali tukar blok lepas siap jem..alik² bila pomen saya check detail rupanya gigi gear crankshaft pomen sebelum dia pergi ubah..memang ada perbezaan bila kita larikan sikit marking gear crankshaft tu..tapi risiko untuk jem sgt mudah...
#pendapat 10sen![]()
aku pun sama cuma klu lari ke atas lg byk dr lari ke bawah...so aku lari ke bwh sket2 yg pelik x dpt mark timing cam selri ngn head..sya pnya mang lari semata..skg sya mark 1 mata ke bawah...
Bahagian engine std ke?2 yg pelik x dpt mark timing cam selri ngn head..sya pnya mang lari semata..skg sya mark 1 mata ke bawah...
yup enjin standad x pnh overhaul g..Bahagian engine std ke?
Ke penah ovehoul?
jd bro mark bg lari kedepan la?aku pun sama cuma klu lari ke atas lg byk dr lari ke bawah...so aku lari ke bwh sket
Motor y150 ke?yup enjin standad x pnh overhaul g..
