advantage ang disadvantage of using rearset
sniper_coj08
mga BOSS what are the advantage and disadvantage of using REARSET?,,How about its braking system?some other said the brake system is change maybe not safe,,,is that true??THANKS,,newbie poh
Paladin
I am also hesitant to install rearset before until I did. At first I'm not used with the new foot peg position and shifting, but I am now comfortable with it. About the rear break strength, I agree with KupaX1R.
In other words, sanayan lang po yan.
About the safety issue, for me it's safer to use rearset. Why? because the foot rest is mounted higher compared with the stock. Also, in stock foot rest your pants always get stuck on the rubber of the foot rest (specially during traffic jams). In rear set, none of it was experienced.
In addition, installing rearset is ideal if you have plans canverting to rear disk break, it is more reliable and has better breaking power unlike to stock you need to do more conversions.
sniper_coj08
I am also hesitant to install rearset before until I did. At first I'm not used with the new foot peg position and shifting, but I am now comfortable with it. About the rear break strength, I agree with Sniper_coj08.
In addition, installing rearset is ideal if you have plans canverting to rear disk break, it is morev reliable and has better breaking power unlike to stock you need to do more conversions.
thanx for the info boss,,im using SMX,,i think i will convert the x1r rearset to fit in my mx,,but some says the break systm will defenitly change,,but majority rearset is best,,ika nga sanayan lng,,and also it depends in the mechanic,,tnx ulit boss,,ridesafe
Paladin
ok b tlg nka rearset,hindi b nkakangalay?
Rearset works perfectly with me. It only seemed uncomfortable at first, but soon you'll get used with it like you don't want to return it back to stock again IMO (This is only based on my own experience).
pg nka stock kc relax eh..pno pg laging my angkas tpos nkarearset?comportable pa dn kya?
I have two complains with my rearset before (specifically the X1R/Sniper rear set). One, When I step on the break I fell off my seat forward. Two, My passenger complains of the uncomfortable position of her foot peg.
How did I solved it? I bought Moto suit seat cover. No slip like my butt had rugby on it. Hahaha!
BTW, I just went to a long ride this day (256 Km distance). I'd rather use rearset than using stock pegs, safer and more comfortable.
wilson09
tnx for the info sir..actually im realy confusing to buy a rearset or not because of the disadvantages..some says its good in racing and banking..my bike is for daily use,always encoutering traffic and a backride..
wilson09
Paladin
Paps, my bike is also for daily use in city driving. For me my bike is easier to maneuver using RS since my foot rest is higher in the ground and makes the bike narrower. Thus, I can slip in between narrow gaps. In stock pegs, my foot most of the time sticks on the stock foot peg but not on RS.
Stock foot rests also have cons. Same is true with RS. It's up to you to weigh in the variables.
neilryu04
Mga paps ask ko lang if nakita ninyo dati na post dito sa T135, nkarearset tapos drum break padin gamit niya.
blade135
ako po pap nkarearset pero drum break..good nmn kpit ng preno q khit bglaan kya..ibang break shoe nga lng gmit q..:D
QAY8401
hELLO!
DID ANY1 HERE USING NUI REARSET / RACING FOOTREST?
I HEARD THAT NUI were products from Philliphines?
jangbest
hELLO!
I`m also Rear set user yamahax1r at 1st, ang hirap gamitin kasi hindi pa ako sanay then after a while, after some minor adjustment on my rear set, Now I`m so very comfortable, sa brake system ok naman makapit naman.Pero its the best kung naka Rear Disk Break hindi na masyado kailangan nang pwersa for brake
Paladin
Ako naman papa jangbest naka rearset din na X1R pro hindi ako sanay sa stock foot peg. Hahaha! laging lumulusot ang paa ko pag apak ko sa likod.
wilson09
advantage of stock foot peg ay pag halimbawang natuba ung motor sa kaliwa o kanan hindi madadamage ang flairing..pg stock passenger peg comportable ang angkas,kaya madami sumasakay na chix sakin kesa sa iba.hehe
