Advice Best Mod For Daily Transport Lc135 4speed Clutch
fiolek67
hi guys, any advices on mods for daily transport and work?
average mileage riding per day 100km.
looking to mod my bike to have a better respond but still can have simple maintenance and good fuel consumption.
sixty-thirty
Few months ago i had just turbo cam with clutch plate and clutch springs install .. it helped with the acceleration. And if its not illegal at your country to use an open pipe get that helps too.. and depending on youe weight you can change the sprokect .and a con air filter helps with the throttle response.
sixty-thirty
And i forgot ... replace the front brk pads with faito onces .. its really really is way better then stock ... not saying stock is bad but its a worthy upgrade .
snipermxmalayaklan
Go super stock, hassle free. High flow air filter, rejet carb, change sprocket, rimset, open pipe, high lift cam, racing coil, rcdi, stiffer valve spring, lose weight.
