Alin Po Dito Ang Nkpagbago Ng Tunog Ng Pipe Ko
aizarn20
dti po nitong tunog eh buo at matigas ngaun po prang ngng prang nob1 n lng po siya low sound n po ahm gold po gmt ko phelp nmn ko kung alin dito ang nkpagpbgo ng tunog po nito
a.removing the whole decomp assy(only cam sprocket left)
b.cms super hardened valve spring
c.cms cam
d. crg clutch spring(remove last friction plate 2 and replace friction plate 1)
e. chane kunya(dti kc may tabas cya kalahati ng kunya) stock timing na lng ngaun
pls po para maliwanagan po ako...o kya may suwaw mc ko sa block o anu po kya?
aizarn20
at pe27 po gmt ko dti wlang backfire ngaun meron na...110 39 po gmt ko nd pa po nagplug reading
alx.cruz
yung cams po.. nabawasan ang compression mo dahil sa cams, kaya po nawala yung tigas/lutong... try mo ibalik yung stock cams without removing the others...
i remember nung nag camprofile ako sa xrm ko dati, nawala, as in nawala yung lutong ng tunog ng yrs pipe ko, naging deep bass lang, to regain the said sound, nag-taas ako ng compression, by istalling a bigger bore...
aizarn20
sbgy po ung cms ata pang 60mm bore po b tma po b ako.kc ung faito turbo sir eh dun tigas ng tunog sir..pwd kya tanggalin ung base gasket pra tumaas comp..ska sir ung pagstroke b ng motor nkkdagdag ng compression?
alx.cruz
increasing you displacement will surely result to higher compression... you can chose by either adding up on the stroke or bore size... removing your base gasket will also increase your compression coz you are moving your piston closer to year cylinder head, hence, there is a decrease in the size/space of your combustion chamber...
regarding installing big valves, this will decrease you compression... the explanation for this is that when you install big valves, you increase the size of your combustion chamber, bigger combustion chamber equates to lesser compression...
that is why engine modification need to be in harmony/compatible with each other...
in short... hindi basta kabit lang ng kabit...
alx.cruz
ahhh 5.5 lift is better than 5.8 lift in 57mm bore sir?
depende pa din po e... there are other things to consider... like size ng intake port, exhaust port, laki ng combustion area, really depends sa mechanic mo...
saka hindi lang po kasi lift ng camshaft ang kino consider, andiyan din yung duration, overlap, etc.
taga saan ka po ba sir? sino po ba gumagawa ng motor niyo?
