MasterJAD
if i'm not mistaken, it nearly 1M.wow i like this helmet..how much is this kind of helmet??
Here are the details:
2012 AGV Pista GP helmet
Pista in Italy means track. So this AGV Pista GP is a helmet specially made for track rider. Previously, this helmet has been codenamed ‘Project 46′ with Valentino Rossi involved in the development of the helmet. This new helmet from AGV is extremely good. Here is what Rossi said about it:
“I am very happy with the interior shell”
“Great aerodynamics, it feels like I am not wearing a helmet”
“Excellent ventilation, it is really noticeable”
“Exaggerated visibility, like switching from the TV to the cinema”.
It features lots of improvement from the previous flagship helmet from AGV, that is the GP Tech. The shell for this state-of-the-art helmet is from carbon fiber which provides lightweight construction and high strength properties. The helmet is made in a process called ‘reverse engineering’, whereby the helmet is designed around the head contours of the rider. In this case, it was Rossi’s head. The visor has been improved with +15 degree opening that helps the rider to view the track better when flat out on the tank. All this without compromising the safety.
One of the concern of a rider like us is about the price. I think this one will not come cheap, maybe you need to save a lot money in long time before you can buy this. Or you can sell your bike to buy this helmet.
AGV PISTA GP TECHNICAL DATA SHEET
SAFETY
• Exterior shell in 4 sizes entirely made of carbon composite fibre.
• Interior shell in EPS in 4 sizes.
• Shell and EPS dimensions optimized using the FEM (Finite Elements Analysis)
system.
DESIGN
• Designed to maximise comfort, ergonomics, safety and aerodynamics.
• Designed to minimise interference when wearing a racing suit and protective hump.
VENTILATION/AERODYNAMICS
• IVS (Integrated Ventilation System) with wide channels hollowed directly in the shell
and holes that allow direct air flow to the rider’s head.
• Ventilation system, designed and optimized in a wind tunnel, comprising 4 front air
intakes (3 at the front and one on the chin guard) and 2 rear extractors.
• Air intakes are in the “always open” position with protective metal frames and
meshes. Plastic caps are available for bad weather. Total surface area of air intakes
193% larger than the GP-Tech.
• Large rear spoiler optimized in a wind tunnel to maximise aerodynamic
performances and ventilation also at high speeds. Spoiler designed to detach from
the helmet in the event of an accident to increase the passive safety of the helmet.
VISOR/ VISOR MECHANISM
• New visor mechanism in metal with roto-translation opening. Quick release system
for tool-free removal and replacement of the visor in seconds. Surface of the visor
mechanism reduced by 71% compared to the GP-Tech.
• Safety system with an external screw attached to the mechanism base, reducing
the risk of the visor detaching in the event of a fall. Visor front locking system that
reduces the risk of accidental opening, also in the event of an accident. Visor micro-opening system incorporated in the front locking system.
• Flat, non-scratch and anti-fog RACE visor with wide field of vision, equipped for
tear-off strips with 100% protection from UV rays.
• Visor, in compliance with the Class 1 optical standard, is free from visual distortion,
with a thickness up to 3.5mm for extra protection.
• Field of vision increased by 15° on the horizon, optimized for a rider lying flat on the
tank. Overall field of vision increased by about 8% compared to the GP-Tech and
the main rivals.
INTERIOR SHELLS
• Removable nose guard.
• Removable wind-proof chin strap protection.
• Fully removable and washable inner liners;
• Breathable, micro-perforated Lycra crown pad with concave 3D structure that is pre-shaped in a single piece according to the morphological characteristics of the head,
without stitching in the sensitive areas, and differentiated density foam. Option of
personalising the crown pad fit at 4 support points, thanks to inserts with
differentiated hardness.
• 3D cheek pads in Dry-comfort with sanitizing treatment, differentiated density foam
and incorporated neck protector for extra comfort and soundproofing.
• Inner liners covered by three patents.
• Double D retention system.
WEIGHT/DIMENSIONS
• Front section reduced by 3% compared to the GP-Tech. Lateral section reduced by
6% compared to the GP-Tech.
• Weight: 1.250g (+/- 50g) for size M.
• Sizes: XS – XXL.
You can check out more information about it here: http://www.agv.com/en/pages/display/pista_gp/index
