john_carlo
transmission sir., different gear ratiopa ot. what about the honda sonic 125, 2 valve only but with 5 speed tranny no power drop on 5th gear. just my experiece![]()
OT: compare that MC between raider125 and Sonic125. the big factor affect to that is POWERpa ot. what about the honda sonic 125, 2 valve only but with 5 speed tranny no power drop on 5th gear. just my experiece![]()
witwew!sir traxx.. what sprocket combi can you give for my SMX.
im currently using 15/42 combi 145 on my speedo so far topspeed
im not that satisfied on that 145 topend so far...hehehe
i need some advice on sprocket combi..
my mods are..
LHK S2 cam
vixion valve spring
rextor Rcdi
61mm bore kit
nakasone clutch spring
denso iu24 iridium
open pipe
WOW..!!sir traxx.. what sprocket combi can you give for my SMX.
my mods are..
LHK S2 cam
vixion valve spring
rextor Rcdi
61mm bore kit
denso iu24 iridium
open pipe
stock or nka load kna bro?i tried different sprocket combi.. so far talaga mas ok ang 15/42 sakin pati sa weight ko 50kilos lng kase ako hehehe...
try ko 14/42 120 valve float 5th gear
14/36 wala accelaration and tagal ng dulo same lng ng topspeed ng nka 15/42
15/36 lalong di ako na contento hehehe.. parang lalo pang bumagal
14/38 and 15/38 di rin mganda hehehe parang hirap ang bagal ng pickup
so far 15/42 pero bka itry ko 43 and 44 di ko lng alam kung ano ang pang front 15 or 16 siguro try ko..
LOADED bro.stock or nka load kna bro?
paps try mo 14x40 baka sakalii tried different sprocket combi.. so far talaga mas ok ang 15/42 sakin pati sa weight ko 50kilos lng kase ako hehehe...
i think bago pa kasi ang smx...pg umabot na nang taon nyan....im sure mas mabilis yan kysa sa 4speed lg na sniper...kn baga d pa masyado na break in...sniper mx is much heavier than the old sniper...
parang dismayado ako sa smx ahh...iniwan pxa nang 4speed sir..what?!!!!byaan ang MX?...
