Bro, unang una dapat naka racing cam na.. Pero Im sorry to disappoint you, hindi yan ang sasagot sa issue mo.. No such thing as magical part na pagka install eh all of a sudden magkakaroon ng major difference..the doctor said:pero sir khit naka 61mm ka na e hrap na hirap pa din talaga sa raider..yung top speed kasi halos konte lng dagdag pag nag big bore ka..ang mapapansin m pagbabago e madali makuha yung top speed compared to stock..
para skin lng mga paps ha .. cdi,carb,at 21 tooth 4th gear .. sasabay n cguro sa raider na stock
@X Project..... o nga sir tama n cguro yung ikaw ang pinaka mabilis at pinaka pogi sa 135cc hehe
e2 n lng isa ang kakargahan ko ...
Walang kaso yun.. Depende sa riding style mo, kung medyo aggressive ka and doesnt mind the top end, then sige lang 15 - 40T is okay but you can go even higher ratio like changing engine sprocket to 14 or the rear sprocket to 41, either of the 2 lang wag mo gawin 14 - 41..vinz0r said:15/40 ok b un for city driving? minor mods, big tires..
Maraming factors to consider like compression ratio pero with 61mm bore, assuming that basic parts for engine modification has been applied such as cam, RCDI etc and nakatono ng maganda ang carb, then okay ang 15-37 given na maganda ang torque ng bike (lightened flywheel and balancer/ inertia plate).. Kung tingin mo mag ssuffer drastically ang bottom end, then use 14-36 420/415..thopiang said:sir x project eto na naman ako
for 61mm bore with stock head, rim set 1.6 f and r with 70/90 tires, top end ang habol. . .
will i use 15/37? am currently using 16/42
thanks
watchmode ako dto...waiting for Sir X project's reactionZukiller said:X Project wrote:
May Sniper din kami na panlaro at masasabi ko siguro na isa kami kung hindi man nauna sa pagbuo ng dragbike using T135 engine... In short po, matagal narin kami kahit papano sa ganitong pakiki-baka ika nga... Alam ko ang lakas ng Raider at ng Sniper sa kahit anong set...
First of all I admire your knowledge in mods & glad that you we're willing enough to share it to our fellow T135 owners.Malakas talaga ang stock na raider kumpara sa stock na sniper pero alam ko ang potential ng sniper given it has the same cc as the raider.Ang pagiging isa or nauna sa pagbuo ng T135 dragbike engige ay hindi din makakapagpatunay na alam mo na lahat ng lakas ng parehong motor sa kahit anong set.It's like saying you have made the fastest running T135 & you know it's limits & you are sure it won't win over a raider.Ofcourse you know about ratio,bore,stroke,compression etc. but those can be easily learned by anyone.Can you prove that you have made a name for yourself w/ your T135 dragbike o kahit sa raider dragbike?Kung hindi pa naman d hindi mo masasabing alam mo ang lakas ng parehong motor sa kahit anong set ser.Pagkat maari din may mas malakas ang set sayo at sa kanila naman ay mas malakas ang gawa nilang sniper kaysa sa gawa nilang raider.Ako naman ser hindi nagmamagaling kasi hindi ako mekaniko pero binabase ko sa mga personal kong nakita lang.
Yes i agree there is no magical part in installing but there is such a thing as proper timing & tuning of other parts to compensate the installed part.
Latebloomer wrote:
maybe a lecture on short stroke and long stroke would help explained
why harwanpepti is faster as claimed by x-project
care for a little explanation also why
sniper lords it over in the UBK races
Gusto ko din makuha ang opinion ni ser X project dito =)
i really dont think straight lahat ng tracks, bat walang sniper nananlo sa mga malaking drag race? it could possibly be from the rider and the track situation, lamang din kc ang sniper sa handling over r150, and yes maraming magagaling na rider who rides suzuki, pero andami nilang di kayang gawin on certain angles of certain race tracks, ive rode a lot of r150's and even tried leaning them to its maximum possible lean angle and iba ang response ng bike pag nasa ganun situation,(handling and rpm increase/drop), i thank you...Zukiller said:X Project wrote:
cams, springs, cdi sir.. So 14/40 my dulo?X Project said:Walang kaso yun.. Depende sa riding style mo, kung medyo aggressive ka and doesnt mind the top end, then sige lang 15 - 40T is okay but you can go even higher ratio like changing engine sprocket to 14 or the rear sprocket to 41, either of the 2 lang wag mo gawin 14 - 41..vinz0r said:15/40 ok b un for city driving? minor mods, big tires..
Again depende sa riding style mo, kung pang city riding lang at wala kang paki alam sa top end mo..
based on expirience...wala sir..120kph max....vinz0r said:cams, springs, cdi sir.. So 14/40 my dulo?X Project said:Walang kaso yun.. Depende sa riding style mo, kung medyo aggressive ka and doesnt mind the top end, then sige lang 15 - 40T is okay but you can go even higher ratio like changing engine sprocket to 14 or the rear sprocket to 41, either of the 2 lang wag mo gawin 14 - 41..vinz0r said:15/40 ok b un for city driving? minor mods, big tires..
Zukiller said:First of all I admire your knowledge in mods & glad that you we're willing enough to share it to our fellow T135 owners.Malakas talaga ang stock na raider kumpara sa stock na sniper pero alam ko ang potential ng sniper given it has the same cc as the raider.Ang pagiging isa or nauna sa pagbuo ng T135 dragbike engige ay hindi din makakapagpatunay na alam mo na lahat ng lakas ng parehong motor sa kahit anong set.It's like saying you have made the fastest running T135 & you know it's limits & you are sure it won't win over a raider.Ofcourse you know about ratio,bore,stroke,compression etc. but those can be easily learned by anyone.Can you prove that you have made a name for yourself w/ your T135 dragbike o kahit sa raider dragbike?Kung hindi pa naman d hindi mo masasabing alam mo ang lakas ng parehong motor sa kahit anong set ser.Pagkat maari din may mas malakas ang set sayo at sa kanila naman ay mas malakas ang gawa nilang sniper kaysa sa gawa nilang raider.Ako naman ser hindi nagmamagaling kasi hindi ako mekaniko pero binabase ko sa mga personal kong nakita lang.
Gusto ko din makuha ang opinion ni ser X project dito =) [/
Mahirap mag explain dito bro pero sasabihin ko sayo diretso na alam ko ang lakas ng parehong motor sa kahit anong set.. Ibig sabihin kung mag lalaro ang Sniper at Raider sa isang category, at alam ko ang karga ng parehong bike, alam ko kung sino ang mananalo.. Nakuha mo ba ang ibig ko sabihin sa "Raider is superior against Sniper" sa lahatng set given na pareho sila ng displacement.. Pag sinabing displacement, it is the sum of the bore and stroke.. Example, a 150cc Raider is always superior to a 150cc Sniper given na parehong all-motor.. Hindi ko sinasabi na palagi angat ang Raider pero most commonly, Raider dominates the Sniper sa drag..
Regarding sa tanong mo kung may pangalan ba ako o sumikat sa pagbuo ng T135 dragbike, ang sagot ko is hindi ako sikat pero kung sino man ang kilala mo na sikat at may pinaka malakas na Sniper lalabanan ko, kahit sino pa yun..
Tungkol naman sa sinasabi mo na displacement computation, bore, stroke etc "can be easily learned by anyone" that's bullshit.. Oo maari mo malaman ang pag compute ng displacement, compression ratio etc PERO pag alam mo na ang value, papano mo gagamitin yun to optimize the power of your bike.. Example, using MTBE, Methanol or top fuels requires a certain amount of compression ratio like 12:1 - 14:1 or even higher pero given na na achieve mo na yung compression ratio hindi ibig sabihin na your bike will run perfect, why? Because you have to perfect the carburetion issue.. Bakit ko sinasabi ito? Gusto ko lang po ipaalam sa inyo na Im not some internet wizard or Google mechanic or in other words Poser.. When I say or type something here, it means that I know my shit.. Pwede tayo mag create ng thread where in I will answer your question real-time and vice versa.. Im a no-nonsense forum member, it explains why my total posts are so few given na Ive been a member longer than most of you guys here.. To all forumers, just because you know how to compute comp ratio, displacement, LCA etc doesnt mean you can go bash your keyboard in answering or providing advise to the person asking.. This forum used to be a very helpful site in regard to tech aspect of the T135 engine not until, bahala na kayo mag isip..
Ako po si X Project aka Jade Tan taga Manila at Mandaluyong, mahilig sa race tech.. May panalrong Sniper.. Zukiller, sino ka po at taga san ka?
BTW, if you want to guage my experience and knowledge regarding T135 engine, mag create ka ng thread at mag usap tayo dun real-time o kaya log in tayo sa chatbox..
Hindi kailangan sikat para sabihin na marunong at may mapapatunayan ang isang tao.. Hindi kailangan tambay ka sa Macapagal at kung saan saan pang drag scene loc para i-base ang runong ng isang tao.. Ang cousin ko, Marlou Acedera got a contract from San Carlo Honda Gressini Moto GP team but Im sure no one here heard of him before.. He got the contract after beating Malay, Thai, Indo, Viet etc mechanics from all over SE Asia in Castrol's Power of 1 Mechanic contest (search thru Google).. He resigned just few months after for some personal reasons and he's now working for Honda in Brunei.. May nakilala ba sa kanya, diba wala? Sir, sino-sino ba kilala mo na may panlaro baka kilala ko rin.. Yung mga advise po na mga pinost ko at mababasa mo dito ay kaya ko patunayan sa drag strip.. Kahit kaninong Sniper, kahit sinong sikat pa yan, hinahamon ko.. Sana may pumatol.. Kasi po yung mga dating thread regarding sa drag ay magulo kausap.. Yung tungkol dun sa Raider na itatapat ni bro P@asimuno eh magulo ang utak, ayaw pala lumaban sa Sniper so hindi po ako ang puro kwento.. Share ko nalang din para malinaw, yung Raider na itatapat samin, hindi lumaban tapos nung nag usap kami ni P@simuno eh 2stroke na 180cc Catalyzer, natural no contest kaya sabi ko ganito nalang para di magulo, Catalyzer nila laban sa Nova Dash namin, 2stroke din po at sabi ko wala na bukasan, umayaw yung kalaban.. Yun po ang buong kwento sa thread na yun.. Pasensya na bro, sobrang haba ng message ko pero aantayin ko reply mo..
Kahit kaninong Sniper/ X1R game ako.. Text or call me..
