Anong Gamit Mo na Bore Up Kit?
jamskie
mga papables..anong gamit nyo na Bore Up kit?
Vixion Kit? Shark? CMR? etc. etc..
and gaano na katagal na ito ang gamit nyo?
ano-ano ang mga tips nyo para tumagal itong bore up kit?thanks mga papa
8)
THE TURKEY
m00nraker said:
VXION KIT AKIN.. 1 YEAR KO NA GAMIT.. Change oil every 500km
UP!!!
OK ANG VIXION KIT KC ORIG YAMAHA AND DIASIL SYA...
PANO NMAN KAYA ANG MGA STEEL BIG BORE KITS NA NDI DIASIL MGA PAFS?
kayode
Super Moderator
sniper_pink said:
vixion kit.. 1 year and 4 months na ok parin ang takbo
d pa nya sinasali ung fact na member xa ng original team waswas...
full throttly mode always to si pink... i know coz ive rode with him many times... :twisted:
kayode
Super Moderator
thopiang said:
61mm cmr steel bore
1 year and 3 months
d mo mapigilan angkol noh! hahaha! pag mamaw mode ang pinag uusapan d makatiis.... hahaha!
lalo tuloy malilito si TS nito.. hahaha! :D
thopiang... mamaw of southeast mindanao... :twisted:
BHER
pa ot ts
para po sa walang alam na tulad ko, ANO PO BORE UP KIT??
anu din po advantage nito sa mc naten ??
levi
Q:
Ano ba ang tamang setup na pang everyday use sa work ang Vixion kit???
carb??
cams??
springs??
cdi??
proper tuning??
salamat po...
thopiang
hahahaha angkol, share lang, tagal na kasi gigil itong si sir rj, ayaw pa tumodo sa engine hahahaha
di ako mamaw, kuting lang nyahahahah
jamskie
gathering info muna ako sir thops..hehehe :D
Rolly
CMR 61 mm steel bore user here. used it already for almost 4000 kms. have used it also for long hard rides.. so far no problem.
performance wise - very good, you could attain higher rpm if you use fully synthetic oil after break-in period.
Rolly
BHER135 said:
pa ot ts
paps ang bore up kit is a cylinder block with a larger diameter than the stock cylinder block. it ususally comes with a kit (cyl block, piston, piston pin and gaskets) because the stock piston can not be used anymore due to the larger bore diameter (bore up).
you could choose among several sizes (61 mm, 62 mm, 60 mm, vixion dont know the bore diameter). the larger the diameter, the better.
advantage: more torque and acceleration.
