ariete handlegrips
tibay-sniper
kainggit, nahawakan ko yung kay marlock hehehe
kukuha ako once bumalik manila si papa ronald para free me shipping hehehe
2b1ask1
up for this, madali lang ba ito ikabit papa dorae? kelangan pa ba ng rugby?
tska yung pag tangal ng stock grips panu po? cenxa na dami tanung. nananakit nadin kasi kamay ko sa stock grips. thanks
the_one
How to Remove and Install Handlebar Grips
There are many different ways to remove and install grips. Here are some of the better ways.
Tools:
Rubbing alcohol, water, hair spray, spray paint, or (gasp!) WD-40
Air compressor
Small flat blade screwdriver
Removal:
1. If you are not going to reuse the grips, cut them off with a utility knife. Just be sure not to damage the handlebar.
2. Lift up the side of the grip using a small screwdriver, and squirt some rubbing alcohol or WD-40 between the grip and bar. Twist the grip off.
3. Pull and twist the grip as hard as possible using your superman arm strength.
4. Use your air compressor to blast air under the grip, popping it off.
Installation:
Always start by cleaning the handlebar. Then try one of these options:
1. Remove the humps of the original handle bar housing.
2. Use an air compressor and an inflation needle to spray air between the bar and grip while sliding them on. This way they go on tight and you don't have to wait for them to dry.
3. Coat the inside of the grip with spray paint that matches the bar, and slide it on. Let it dry. It shouldn't slip around because the paint works like glue to hold the grip on the bar.
4. Use your superman arm strength to shove the grip onto the bar.
5. Spray some WD-40 inside the grip, and slide it on the bar. Slide it off, and wipe the bar down. Slide the grip on again. This time it should be a little harder. Let the grip dry.
You can do the same thing with rubbing alcohol if you don't want WD-40 near your bike.
beaumeds1
sir dorae, pa pm naman ako ng price oh. saka ng location if ever. hindi kasi ako marunong magkabit eh, kaya papakabit ko na din sana.. hehe!! salamat.. sakit nga ng stock grips..
2b1ask1
Tools:
Air compressor
Removal:
Installation:
sir thanks very much for the info.
ryioki1
Tools:
Air compressor
Removal:
Installation:
eh panu tangalin ung bakal sa bukana ng handle grip.....yung ikot lng ng ikot....?.
Undah-Bone
up for this item..
ang sarap po sa kamay ng grip na toh.. sobrang kapit at sobrang lambot kaya kahit hindi ka na mag gloves hindi magkakakalyo ang kamay mo.. sarap for everyday use at kahit sa long rides masarap gamitin.. hindi kayo magsisisi pag bumili kayo neto..
UP..
arjaydotcom
papa dore bukas po pwede po b u ng maga tom.? or kahit mga tanghali? dati po kumuha ko sayo ng shock cover maga din tayo ngkita sa my monumento...
