ASHNIK my Buddy my WARRIOR
JhayBoo
@ice - bro matagal ng ipon yan naghihintay lang ng tamang item :) ..saka hindi ako mahilig sa pipe --di uso sa akin un...
LF : YY PANG hahaha
@nyr - hindi pa ko mamaw mode bro - yang nabili ko pamalit lang sa mga nagasgas ko :D ..malay natin kaya ko pala binili yan para sau ..nirereseve ko lang para sau hahaha
auz sa mga banat ah...hooooyaaaah!!! yypang... bkt dka tumingin sa for sale section bro?!:D:p:eek:
nyr0
LF : YY PANG hahaha
nice nice.. ge w8 ko yng mga pinareserve mu para sakin :D
zcbitik
@nyr -- uu ba pero same price with kent ha hahaha
@marulas - naku sir hnd po sia headturner simple lang po yan..
acidrain
you can use tire black bro, kng ddisplay mo lang motor mo... showbike ba..pero kng ggmitin mo sa daan yan... might as well think twice..delikado yan.. tama c rs, dudulas lang yan bro...
nway use tire black nlng pag tamang display lang..IMHO...hehe
tama, unang semplang ko dahil sa tire black, kaya muna noon hindi na ako gumamit nito
zcbitik
@jeffmac - if I am not mistaken pap's it is 80..di ko napapansin eh.. di ko naman kasi tinitingnan.. i'll double check pag uwi ko :) then update kita ..nabili ko na kasi yung motor na yan na ganyan kaya wala akong pake sa gulong unless mag papalit na ako saka lang ako titingin :D
zcbitik
It's been so long :).. now will try if I am good on a make over project, it is ASHNIK kikay kit
parts currently on hand
1. Biker's bar end
2. Okimura lever
3. 1 piece Brembo Caliper for Rear (will think if need to replace the front too :D )
4. Racing boy Swing arm
5. Stainless bolt
6. Engine Cover ( two avail either plastic or stainless, let me see)
7. LED eagle eye (where should I need to put this one? ) :D
8. FE designed for the MASK with dragon tail :D
7. Chameleon MASK :D courtesy of nyr0
still waiting for the next fund for
1. X1r Rear set
2. Pipe (prepared HGM Big elbow longingly with silencer)
3. wheel lock dunno the name will edit nxt time
4. left hand brake kit (will convert foot brake to left hand brake) is it safe?
5. long braided hose around 5ft or two piece with connector (i wish this is possible)
6. quick throttle ..dunno why :D
7. Mono shock (combiz - adjustable)
8. that harness :D
9. solcar or option 1 (is it fit the mio/nouvo solcar to the MASK? thinking alot here :(
9. reserve for the mean time.. still thinking of what else need to source out
I just listed the parts here in order for me not to forget what on my project list needed
my question now is ...when should I need to start? :D
nyr0
unti unti lang sir.. sa dami nyan baka mapagalitan na ni esmi kasi ubos oras yan sa pagkuting ting mawalan ka na time para sa mga kids at family bonding..
pro just incase i hope you also have ur tools in order to respond to the future mods ur planning if you want to DIY
zcbitik
@nyr - uu pap's unti unti lang naman :) iniipon lang para complete na
@ricky0822 - muntik ng maging for sale talaga yan pap's kaso nanghinayang ako eh buuhin ko na lang ulit..
zcbitik
isang taon din na paghahanap at pagiipon yan pap's saka pakiusapan... tiwala ika nga.. kung tiwala sa akin ung seller na magbabayad ako kahit in terms ayun ska ako nakaka bili :)
marami pa ako kulang dyan sa cosmetics sayang lang ung ibang item na nauuhanan ako di kasi ako madalas tambay sa selling :) pero pasasaan ba hehehe
pag ok na to dayuhin kita ask ko kung ano pa ba mga need to know about this Cosmetic Surgeon :D
zcbitik
just a little update, after a few months of waiting.. I am almost 85% of my Cosmetic project :D
what was on list last Oct 1, 2013 till today
1. Biker's bar end --I dunno where is this now, I forgot where I put it :(
2. Okimura lever -- done on the right lever
3. 1 piece Brembo Caliper for Rear -- done and will think if need to replace the front too :D
4. Racing boy Swing arm -- done but had a little problem with my yoshimura backride footpeg
5. Stainless bolt -- done on front
6. Engine Cover ( two avail either plastic or stainless, let me see) --still trying to put it but have a little problem w/ the bolt
7. LED eagle eye (where should I need to put this one? ) :D -- I used one as rear light for plate no
8. FE designed for the MASK with dragon tail :D --done with a little modification
7. Chameleon MASK :D courtesy of nyr0 - done with a little fitment
additional parts
left lever (foot brake conversion) -- done on conversion
LED signal light --done and put it on the dragon tail
Monster chain tensioner -- not yet installed
New front Braided hose -- not yet installed
New Front shock --dunno the brand and for confirmation
New Rear shock (vixo) --for confirmation
New LED rear brake light --dunno where to put this one :D
New RB spooler --courtesy of sir @nyr0
Daytona QT with 3 switches --on hold
Belly pan - not yet installed
front fender (R6 alike) not yet installed --no bracket :(
front brake stop switch - installed
seat lock(replace broken) - installed
drain plug - not yet installed
New RB oil filter cover - not yes installed
New side mirror - look like vega force mirror but small version not yet installed
New RB fork stabilizer --not yet installed, dunno if will still fit because my bike is lowered
Gas filter - dunno how to fit and where to put.. :(
UMA QT has been installed - this is to resolve the response problem of the carb
1. X1r Rear set --not continue coz my RS has been repaired
2. Pipe (prepared HGM Big elbow longingly with silencer) --did not continue coz I bought a copy pipe
3. kinbar wheel lock --waiting for the time to be use
4. left hand brake kit (will convert foot brake to left hand brake) is it safe? --done installed
5. long braided hose around 5ft or two piece with connector (i wish this is possible) --done installed
6. quick throttle ..dunno why :D --hold for the meantime
7. Mono shock (combiz - adjustable) --just replace with vixo --cheaper but not adjustable :(
8. that harness :D --still waiting for this one (no budget as of the moment :( )
9. solcar or option 1 (is it fit the mio/nouvo solcar to the MASK? thinking alot here :( --Option 1 has been installed
thingking if need to replace front caliper or just repaint? :(
price? = AMNESIA :D
NOTE : APRIL's FOOL's Day
  • Like
Reactions: Gie
Gie
@zcbitik ... good luck to your mods sir, we'll wait for the new look of your mamaw bike... don't forget to update the pics..;)
