assorted racing parts for yamaha sniper135
Kichi YZ
meron po b kyo nito magkano ho for Sniper MX:
- vixion kit
- yamaha valve Spring
- rcdi
- mikumi 28mm carb
- s4 evo cam
saka ipa-valve pocket q n rin po..
pls pm me or text me 09478796961
Lester Chua
brt powermax hyperband cdi for sniper 3400 pesos updated price
racing rear sprocket aluminum 415 size 39 1pc 1300 pesos
racing rear sprocket aluminum 415 size 40 2pc 1300 pesos
faito racing chain 415 1200 pesos available color (gold only)
oko flatslide carb available size 24,28, 30mm 1900 pesos
uma 62mm ceramic chromebore kit for sniper 8200 pesos
rear disk brake assembly double piston 1800 pesos 1 set
rear diskbrake assembly single piston nissin 2300 pesos 1 set
Faito Infinity Block 60mm kit 3,400 pesos
Turbo Camshaft 2,500 pesos
S4-Evo Camshaft 2,000 pesos
Clutch Spring Zero 600 pesos
Engine Valve set 1,600 pesos
Ignition Coil 7400 universal 1,500 pesos
MTRT valve spring 1700 pesos
NCY valve spring 900 pesos
FTK thailand cams 5.8mm lift 1700 pesos
X-RAY steel bore block 2000 pesos including shipping
snam cam oem packaging 1200 pesos only
Sir emcid ung x-ray na block ok ba yan thanks sa feed back interested aq db 62mm yan???
ska ung 61mm piston kit mgkno ulit???
