assorted racing parts for yamaha sniper135
004411
brt powermax hyperband cdi for sniper 3400 pesos updated price
racing rear sprocket aluminum 415 size 39 1pc 1300 pesos
racing rear sprocket aluminum 415 size 40 2pc 1300 pesos
faito racing chain 415 1200 pesos available color (gold only)
oko flatslide carb available size 24,28, 30mm 1900 pesos
uma 62mm ceramic chromebore kit for sniper 8200 pesos
rear disk brake assembly double piston 1800 pesos 1 set
rear diskbrake assembly single piston nissin 2300 pesos 1 set
Faito Infinity Block 60mm kit 3,400 pesos
Turbo Camshaft 2,500 pesos
S4-Evo Camshaft 2,000 pesos
Clutch Spring Zero 600 pesos
Engine Valve set 1,600 pesos
Ignition Coil 7400 universal 1,500 pesos
MTRT valve spring 1700 pesos
NCY valve spring 900 pesos
FTK thailand cams 5.8mm lift 1700 pesos
X-RAY steel bore block 2000 pesos including shipping
snam cam oem packaging 1200 pesos only
Sir meron pa x-ray steel bore 2000 including shipping. Salamat
emcid_ubp
teka lang natabunan na to hehhe,
new items for sniper 135, monoshock yes racing..
mataas lang ng 5mm sa stock para sa mga gusto mag lifter na sumasayad kapag malaki ang gulong ,eto na po kasagutan sainyo..
salamat sainyo mga paps..
Ako si e-ow
Mura to ah! sana makabili.. UPPERCUT sa iyo boss Emcid!
Paladin
I bought this for my sniper. I'm using it for about 3months now and I say It has an excellent performance considering that I always have back ride. Instant lift. No need to extend your center stand.
sniperyaz
how much po ito? and ilan po max load weight capacity po niya? thanks and up!
