backfire...
adam_john99
Mufaf LC baru 5speed ke?
Valve spring tukar baru ada ummpphh...Hahahaha ;)
PHL adrion rm170? Okla tu Terbaeeekk...Wakikikiki...:D
Adam John moto cna skrg ada p'ubahan baru?? :p
-Wah..YamahaT135.com ni makin rancak blk skrg...Hehehehe...All newbie,new rider welcome joint...:)-
alo otai kamen, so far motor ok jer just ingat nak rejet balik carb tue kalau ade mase sbb kalau merembat asap hitam still kuar skit jer....hmm, tunggu bro kamen kasi pendapat pasal degree cdi utk spec yang saye tanyer tue la...hehehehe, rase2 nak letak brape??30 btdc??rpm saye cut kat 10k jer, mcm takot nak rem lebih2...
phl6684
set je 12k...klu set 10k...kta bwk smpai cut-off...nnt jd len plak enjin tuh...da overrev...
klu set 12k...at least safety kta bwk dlm 10k...
jgn biar enjin tuh overrev lama2..kang ke atas atau ke bwh rod kta nie...
MuFAF
bro MuFAF, ko try main pj35 and mj 115 dulu, then tgk macam mane ade kuar asap tak and check plug, sbb aku pun layan uma 28mm, tapi blok aku 60mm jer....mcm mane penangan 62mm??mantap tak bro....???
bro, aku da test... size yg ko sarang kn nie... ade letup2 sket bile decelerate.. plug aku tak check lg... tp mmg clear.. asap tak de... kalau ade asap hitam or putih ape maknenye?? psal letup2 tu silap aku adjust carb ke kne main mj ngan pj... nk try 110 pulak pas nie... hurm.. pening pale... denyut2 da...
adam_john99
bro MuFAF, kalau ko dah pakai pj35 mj115 rembat full throttle pun tak kuar asap itam, kira dah cun sket dah tue, yang letop2 tue plak maybe dari pj besar sket....cer try tgk plug dulu yer....
phl6684
klu da xde asap,semua jln ok running ok..klu cek plug pon ok...tutup semua hos yg masok kt head...kompom ilang letup...
MuFAF
plug aku test dgn plug baru... try pj 35 mj 115... kaler plug tu yg tgh warne putih still putih.. dlm tu hitam perang2.. batang fius perang gak... lua tepi2 tu pun perang lg... okay ke??
adam_john99
moto semput lagi ka bro???naikkan mj sket sbb yang putih tue still putih lagi, kalau bley dapatkan warna keperangan semua bahagian....
MuFAF
hos ais yg bro maksud kan nie.. die masuk duk kat kotak angin kan dulu?? skarang sye tak pkai da.. tp hos tu still ade... kalau tutup tu nk tutup dgn ape?? ke jauh kn hos tu dari carb?? ke tutup je trus??
adam_john99
tutp je pakai skru besar2 sket bro....
MuFAF
setelah sye tutup lubang hos tu... mmg tak takde bunyik letop2 tu bro....
terima kaseh byk sbb bg tunjuk ajar...
moto da tak semput... api da tak kuar.... semue part memuaskn stakat nie... uma punye set ade ke yg mj lebay 115 bro? kalau ade sye nk try....
esok maybe nk settle kn hal valve spring tu....
mekaseh bro PHL ,ADAM n KAMEN.... tringt nk jmpe... blanje teh tarik...
adam_john99
boleh bro, die pun kate kat plug normal tue....'insulator nose grayish-white or greyish-yellow to brown.....gelapkan sket pun takper....insyallah tak makan piston....
MuFAF
thanks bro... sebelum nie.. pomen tu tamau setting 115 35... die kate tak ley masuk minyak.... tp hari sye try usha spark plug... hitam legam...
tu yg setting mcm bro2 semue suggest... trbaik pulak... time kaseh bbyk.. bole tdo lena mlm nie...:D
