bro ronnelronnelmarc_21 said:@Toyds,..
OK thanks too,..If you don't mind I suggest also to put one diode each like 1N4001 parallel to the coils of your relays to avoid "inductive kick",..the diode will discharge the coil if you turn off your relays,..dont touch the wire connected to the coil,..the is "induced voltgae & high energy there" if your turning On & Off your relay..
Your diagram will work for me.
bro ronneltraxxas-modifier said:[quote="ronnelmarc_21":1mkayunv]@Toyds,..
