Best Battery For Sniper
jangbest
thanks sir! how often should we refill our batteries?
Check your battery regularly if you found out that the water of your battery is low level then refill it..... for maintenance purposes if you forget to refill your battery and the water is drained due to everyday use oron long rides battery will shorten lifes span or worst your battery will get busted .....
how much for the motolite conventional battery? just planning to buy one of that too.. and please include the details if you don't mind tia!
I do not suggest to use This battery Motolite conventional specially using HID, i have experience low bat even if my wiring converted to fast charging .... i replace my 2 months old Motolite to Brand new Quantum Battery and bwallaaahhh ..... i have a happy day using my HID on this battery ...
is this QUANTUM BATTERY you saying is MF or refillable water battery?how much it cost?
jamskie
what modification exactly is that sir...? Kindly share for our bro's.. TIA
papa @rowan and @Moto Flash did the modifications so that the raider150 battery 6amps could be fitted to my snipey. i noticed they cut the top cover of the battery. actually the original plan is to cut / modify the place for battery so that the battery of XR200 w/c is 9amps could be fitted. but they ran out of time. hehe
nyr0
is it maintenance free or the conventional one?
