also consider the material coz camshafft made out of several different types of material..X Project said:Okay, are you ready? Dont focus on the stereotypicall tradition of stages terminology... If you buy cam, be ready to know what you want and your objective... Research on CLA (Center Lobe Angle) to get the specific lift you want and then the duration... Usually for bigbore kit, the best is 310 - 330 degrees duration overlap using plus 6.10mm - 6.30mm additional lift from the CLA... Bro, you can do some research on the net but unless you tried it yoursefl, you wouldnt really understand the effects of modification bro... The given example is based on most common and personal tests and experience, if you tend to falter from my example, feel free to do so and be ready to charge it to a very expensive experience man...ryioki1 said:waaaa..at last cams brand....!
what about their sizes...?stages....?and compatability...?
sir super posible coz vincent did a 145kph on my bike @ the ff specs:raider125jeigh said:Bro x-project would you believe the specs below can reached 130kph on 3rd gear?
155kph topspeed.
X1r push start
-stock bore
-BRT CDI
-YY pang clutch spring
-15 x 39 sprocket
- Pluto cams
- YY pang big elbow longy
-26mm CARB
-SP ??
- Rim set
- 60 x 80 and 70 x 80 tires… or mas maliit pa…
gusto mo pumalo sau ng ganyan?raider125jeigh said:Bro x-project would you believe the specs below can reached 130kph on 3rd gear?
155kph topspeed.
X1r push start
-stock bore
-BRT CDI
-15 x 39 sprocket
- Pluto cams
-26mm CARB
-SP ??
- Rim set
+1 ako d2. eheheh...the_one said:sir super posible coz vincent did a 145kph on my bike @ the ff specs:raider125jeigh said:Bro x-project would you believe the specs below can reached 130kph on 3rd gear?
155kph topspeed.
X1r push start
-stock bore
-BRT CDI
-15 x 39 sprocket
- Pluto cams
-26mm CARB
-SP ??
- Rim set
- stock bore
- BRT CDI
- clutch spring
- 90/80f 90/90r-17
- 13/44 415
- racing cams
- 24 carb flalt
+1 ako d2. eheheh...kenshin_blade09 said:[quote="the_one":1i0sweqw]sir super posible coz vincent did a 145kph on my bike @ the ff specs:raider125jeigh said:Bro x-project would you believe the specs below can reached 130kph on 3rd gear?
155kph topspeed.
X1r push start
-stock bore
-BRT CDI
-15 x 39 sprocket
- Pluto cams
-26mm CARB
-SP ??
- Rim set
- stock bore
- BRT CDI
- clutch spring
- 90/80f 90/90r-17
- 13/44 415
- racing cams
- 24 carb flalt
just spank me on my head.. hehehe...kenshin_blade09 said:gusto mo pumalo sau ng ganyan?raider125jeigh said:Bro x-project would you believe the specs below can reached 130kph on 3rd gear?
155kph topspeed.
X1r push start
-stock bore
-BRT CDI
-15 x 39 sprocket
- Pluto cams
-26mm CARB
-SP ??
- Rim set
- 60 x 80 and 70 x 80 tires… or mas maliit pa…![]()
AYOS BIG BIKE HAHAHA.. 145kph 3rd gear huh.. 125kph lng 3rd ko hirap p huhuhu..oicat said:lakas naman nun 130 3rd gear???? maniwala ako!
mas malakas to 145 3rd gear!!!
whoah! ang lalakas ng motor nyo!
+1 ako d2. eheheh...the_one said:[quote="kenshin_blade09":2gynpolz][quote="the_one":2gynpolz]sir super posible coz vincent did a 145kph on my bike @ the ff specs:raider125jeigh said:Bro x-project would you believe the specs below can reached 130kph on 3rd gear?
155kph topspeed.
X1r push start
-stock bore
-BRT CDI
-15 x 39 sprocket
- Pluto cams
-26mm CARB
-SP ??
- Rim set
- stock bore
- BRT CDI
- clutch spring
- 90/80f 90/90r-17
- 13/44 415
- racing cams
- 24 carb flalt
+1 ako d2. eheheh...kenshin_blade09 said:[quote="the_one":249bkw1b][quote="kenshin_blade09":249bkw1b][quote="the_one":249bkw1b]sir super posible coz vincent did a 145kph on my bike @ the ff specs:raider125jeigh said:Bro x-project would you believe the specs below can reached 130kph on 3rd gear?
155kph topspeed.
X1r push start
-stock bore
-BRT CDI
-15 x 39 sprocket
- Pluto cams
-26mm CARB
-SP ??
- Rim set
- stock bore
- BRT CDI
- clutch spring
- 90/80f 90/90r-17
- 13/44 415
- racing cams
- 24 carb flalt
isa lng sasabihin nya 155kph or more whahaha...oicat said:lets rock!
let my bike do the talking!!!!
+1 ako sa out of this world cams..oicat said:lets rock!
+1 ako d2. eheheh...kenshin_blade09 said:[quote="the_one":39hsewx8][quote="kenshin_blade09":39hsewx8][quote="the_one":39hsewx8]sir super posible coz vincent did a 145kph on my bike @ the ff specs:raider125jeigh said:Bro x-project would you believe the specs below can reached 130kph on 3rd gear?
155kph topspeed.
X1r push start
-stock bore
-BRT CDI
-15 x 39 sprocket
- Pluto cams
-26mm CARB
-SP ??
- Rim set
- stock bore
- BRT CDI
- clutch spring
- 90/80f 90/90r-17
- 13/44 415
- racing cams
- 24 carb flalt
ayaw nyan makakakita ng sasakyan s harapan nya paps hehehe.. may sariling mundo yan sila nla vincent!!!pEkz said:kagabi nga bigla nawala c black mamba sa c5 eh.... nalampasan lang ako ng kotse tapos bglang nawala.... apmf!
