Best Clutch Springs For Our Snipy
kr.r_sniper
is there an isyu regarding xcs? its ok. i have used it with my 210cc daily driver without any problem. i have used xcs, unleaded, g-5, blaze, velocity, etc without any problems. higher octane rating does not equate with higher horsepower. unless its oxygenated fuel. higher octane rating allows you to go higher compression without the risk of detonation. higher compression means more power.
How about METHANOL :D
docgabby
blaze po o gasolina ng eroplano he...he
Can I run AvGas in my vehicle?
AvGas is short for Aviation Gasoline. AvGas is of interest to motoring enthusiasts because of its availability, octane rating and low price compared to commercial race fuels. AvGas might seem an obvious choice but closer study raises some doubt.
AvGas LL100 stands for "Low Lead 100 Octane". TEL (Tetra-ethyl-lead) is added to raise the octane. When used in a motor vehicle this fuel will leave a lot of lead deposits in the motor. 100LL has a high lead content (0.5 grams per litre) compared even to leaded race fuels. The deposits left when TEL is burned are corrosive and damaging to valves, valve guides, valve seats and cylinder heads. Lead deposits will also block oxygen(lambda) sensors and catalytic convertors and foul spark plugs even after only a short use. Also, 100LL has a chemical package added to make it perform at high altitude, and that isn't the best thing for motor vehicle performance here on the ground.
AvGas is blended for large-bore, long-stroke, low rpm engines which run at high altitude. While AvGas' higher octane is useful, smaller-bore, shorter-stroke, high-rpm engines will perform better on racing fuel or high quality octane boosters. AvGas has lower volatility so when used in proportions higher than about 40%, part-throttle drivability and cold starts may be compromised. AvGas has a lower specific gravity so it will require a change in air-fuel ratio calibration for the engine to perform at its best. LL100 is blended with a high percentage of aromatics that reduces throttle response which is not an issue with an aircraft engine but certainly an issue in a high-performance automotive engine. These high levels of aromatics will also damage rubber components in automotive fuel systems such as fuel lines, fuel pump seals and injector washers.
The sale and use of AvGas is heavily-regulated. Most aircraft fuel dealers refuse to put AvGas into anything other than an aircraft fuel tank. There is a legal grey area that has some vendors willing to dispense AvGas into "approved" containers if they believe the end use of that AvGas is fueling an aircraft engine. This loop-hole is how some may obtain AvGas for automotive use. Because AvGas has no taxes and duties on it, use on public roads is illegal and if found could result in your vehicle being impounded.
The Bottom Line:
Avgas may be suitable for some race cars that don't have catalytic convertors or oxygen sensors and are rebuilt often enough that the TEL build-up is not an issue. For other applications use an unleaded race fuel or a good quality octane booster.
docgabby
Racing Gasoline Verses Aviation Gasoline written by, and thanks to
Tim Wusz
76 Products Company
I am going to attempt to address the controversy of aviation gasoline verses racing gasoline for use in race cars. Some racers use aviation gasoline which is fine for some applications but does have shortcomings. There are several grades of aviation gasoline (avgas) that we must identify before going any farther.
1. Avgas 80/87: this product is used in low compression ratio aircraft engines, contains little or no lead, is red in color, and should not be used in any automotive engine due to a low motor octane number of about 80.
2. Avgas 100/130: this product that can be used in some automotive engines. It has both research and motor octane numbers slightly over 100. Avgas 100/130 is green in color, contains four grams of lead per gallon, and is becoming harder to find.
3. Avgas 100 LL: the LL stands for "low-lead" which means two grams per gallon, low compared to the avgas 100/130 that it was designed to replace. It has research and motor octane numbers very similar to the 100/130 product previously discussed. The color is blue. This product sometimes has a high level of aromatics which can contribute to lazy throttle response and dissatisfaction of the consumer.
4. Avgas 115/145: this product was developed for high performance piston aircraft engines used in world war II and in the Korean war. It is very hard to find anymore due to lack of demand although it is of very high octane quality. The color is purple.
The remainder of this discussion will assume that our basis for comparison with racing gasoline is avgas 100/130 and/or 100 LL since they are both available and have acceptable octane quality for limited applications. When the word "avgas" is used, it will refer to avgas 100/130 or 100 LL.
Avgas is less dense than most racing gasolines. Instead of weighing about 6.1 to 6.3 pounds per gallon like racing gasoline, it weighs 5.8 to 5.9 pounds per gallon. The racer must compensate for this by changing to richer (larger) jets in the carburetor when changing from racing gasoline to avgas.
The other major difference is octane quality. Avgas is short on octane compared to most racing gasolines. Many racing engines with "quick" spark advance curves or with no centrifugal advance have more spark advance at low rpm than avgas and some racing gasolines can handle. The result is detonation, especially during caution periods in circle track racing because all of the spark advance is "in", rpm is low, and part throttle air fuel ratios are too lean for the operating conditions. If the driver does not "work" the throttle back and forth, pistons can be "burned" which melts away part of the aluminum piston material. Inadequate octane quality is one of the quickest ways to destroy an engine. Pistons can be severely damaged during one acceleration where detonation is present and the racer may not know what is happening until it is too late.
For maximum performance and power from a racing engine, racing gasoline will normally provide better performance than avgas. Avgas can be a good gasoline for some applications, but since most racers do not know the octane requirement of their engines, they would be better off with a "real" racing gasoline that will give them the overall resistance to detonation that they need to protect their investment. If someone has spent from $15,000 to $50,000 or more on their racing engine, it is foolish to cut corners on gasoline be sure you have a gasoline with adequate octane quality.
written: 11/16/95
docgabby
Racing Gasoline vs. Aviation Gasoline
Summary: Don’t substitute Aviation Gasoline for racing gasoline unless your race engine operates at
10,000 feet altitude, and does not exceed 2800 RPM.
Many racers see Aviation Gasoline (AvGas) as a way to reduce the cost of their racing operation. This may be
true, but if you want the most out of your engine and want to avoid problems, AvGas may not be your first
choice. AvGas is a good gasoline for low speed aircraft engines that run at 2700 to 2800 RPM at 10,000 feet
or higher. This does not mean it is a good gasoline for racing engines operating at 8,000 to 10,000 RPM.
AvGas is also illegal to use in anything except aircraft engines. Violations can carry a potential penalty of
$25,000 per day of violation.
AvGas octane numbers are determined in a different test than motor gasoline octane numbers. Do not be
confused by the big numbers from the AvGas test method. They are not comparable to motor gasoline test
numbers. The 111 octane version of Rockett Brand TM Racing Fuels tests at 160 on the AvGas Scale.
AvGas is held to tighter requirements than street gasoline, but not nearly as tight as is the entire line of
Rockett BrandTM Racing Fuels. Some racing gasoline blenders use AvGas as a blending component to save
money. For Rockett Brand TM Racing Fuels, we do not. We use only the highest quality components since
AvGas is far too inconsistent to use as a blending stock for Rockett Brand TM Racing Fuels.
AvGas has a lower specific gravity than most racing gasolines. This means that if a racer tries AvGas and has
not re-jetted, he can burn a piston because the air-fuel ratio is too lean and/or the engine detonated. To make
a good comparison between two gasolines, the air-fuel mixtures must be the same. Even after re-jetting, the
racer can experience burned pistons with AvGas if the Motor Octane Number (MON) is lower than what his
or her engine needs.
Another potential problem with AvGas is that there are several different octane grades. The 80/87 grade is
red in color and can get you in lots of trouble because of its very low octane number. The 100LL is blue and
the 100/130 grade is green. Both of these have much lower Motor Octane Numbers than most racing gasolines
and will detonate when the engine octane demand is greater than the octane number of the gasoline.
The bottom line is: Feed that high dollar racing engine a good grade of gasoline so it will deliver the maximum
performance for you. Don’t use “low bidder” mentality. This is not the space shuttle.
For Your Nearest Rockett Brand TMRacing Fuels Distributor call: 800-345-0076
Pg. 1 of 1
© 2008
Samboy Del Rosario
crg pinaka maganda for me. para din sakin hinde sya matigas, 6spring ka tapos i crg mo na! lalaki pa forearms mo. hehehe.. ^_^
hahaha natawa nman ako rito.. dual purpose may exercise pa hehehe
Mga papz how about nakasone spring?
im using nakasone clutch spring too bought it from sir traxx..
hinde nman cya ganun katigas and compare sa stock may ok cya.. pang daily use ok magnda nman pick up.. hinde ka mahihirapan sa pag pisil pisil ng clutch comportable..
pero mas ok kung nka 6spring clutch.. ipon mode mag kakabit rin ako nito.. swak kaya yan sa SMX? plug n play any info? TIA :rolleyes:
ehh papano pala kung mag IKK match din ba to?
ronald031803
me too, i use LHK, mula ng mabili ko snipee ko pinalitan ko na agad ng clutch spring,still no problem
di sya sobrang tigas pero me pitik pag release ng clutch lever
towendz
Me? Crg Plus washer :shag: pag naganda bitaw sa 2nd gear pwedeng mag wheelie. stock sniper with 15/42 sprocket :coffee:
towendz
lakas paps ah..bat may washer pa?..edi parang hindi ka din naka springs nyan?..
muka lang malakas paps dahil lumulundag :D.. bakit naman po parang ndi naka springs?. ung sakin naman lalong gumanda ung talon nung nilagyan ng washer. :cool:
