supermikoman
what is the proper jettings for keihin 27mm? i currently have 40 and 43 for pj. and 105 and 115 for mj. whats the best suited fo my all stock angine with stock pipe? if its not there kindly tell me what sizes should i buy
anong pagbabago napuna mo from stock sir?Sir I'm currently using that carb on my sniper mx and the stock jettings are installed.. But as far as I remember, we've changed my main jet to 115 if I'm not mistaken then the pj is remain unchanged.. Then the jet needle setting was at the bottom most.. My engine is stock and using stock pipe, but now I've only changed my pipe to a performance pipe.. I think size of jetting is trial and error because it depends on the ambient condition, humidity and elevation at sea level etc.![]()
My set was quite restricted because I'm still on stock even I've already changed my pipe to an open one.. Planning to install my Kawahara K1 cam when I already got at my hand the vixion valve spring and BRT dual band..
I I'll stick on my stock bore... at this moment..
good luck to your modding sir. im gonna wait for your future mamaw sniper.hehe.and thanks for your inputs!. ride safe and godblessThe carb that was installed on my bike was stock carb of sniper classic so if I'll compare to it, there's a big difference when it comes to response since I have a bigger carb.. And I noticed that my gas consumption got high.. hehehe But during "ratrat" mode only..My set was quite restricted because I'm still on stock even I've already changed my pipe to an open one.. Planning to install my Kawahara K1 cam when I already got at my hand the vixion valve spring and BRT dual band..
im also suffering from my keihin 28 round slide it was difficult to tune and difficut to find jettings... your lucky to buy that 27 mm coz it had needle settings not like mine...Sir I'm currently using that carb on my sniper mx and the stock jettings are installed.. But as far as I remember, we've changed my main jet to 115 if I'm not mistaken then the pj is remain unchanged.. Then the jet needle setting was at the bottom most.. My engine is stock and using stock pipe, but now I've only changed my pipe to a performance pipe.. I think size of jetting is trial and error because it depends on the ambient condition, humidity and elevation at sea level etc.![]()
thanks for ur input bro. heheim also suffering from my keihin 28 round slide it was difficult to tune and difficut to find jettings... your lucky to buy that 27 mm coz it had needle settings not like mine...
try using pj 37 and 108 mj with rcing air cleaner..result..better acceleration and better mileage
the problem is it was difficult to find mj 108
Better acceleration and can reach the RPM fast.. I felt the power when I changed my pipe to open one..anong pagbabago napuna mo from stock sir?
