Best Sprocket Combi
weng82
any suggestion mine is stock engine but 28mm carb, when i shift to 4th gear its stiff or shall we say choking condition, my sprocket combi 16/36 some say my combi is miss much coz the 16/36 combi is for 170cc engine any advice pls i plan to change my combi to 15/40 isn't for good already?
jangbest
I think it's not related on Sprocket Combi "Correct me if I`m Wrong" choking chorva on your carb was maybe related to jettings IMHO.
Regarding on Sprocket combi as always says it depends on your Preferences, Road Condition, rider weight, and tire size.
weng82
if so sir what settings will you recommend? pls i need your help to fix my ride thnx in advance
Jackocc
If you want higher top speed and not sacrifice acceleration with your tire combination please use 15-40, or you can use stock sprocket combination 15-39 with change on 4th gearbox ratio so your engine don't go overdrive when shifting your gear from 3rd to 4th.
Can I just change the 4th gear ratio for daily drive with my stock engine ? What is the best ratio for daily drive in Penang island 20T or 21T
jangbest
Hi Bro.
thanks for the reply, so if me change to 21T would i loss my power when I go up hill ?
or it will not effect me go uphill , and It will increase better rich at top speed?
upgrading 4th gear it will definitely improve your 4th gear performance but on sprocket combi still trial and error for what a driving style and road condition you have.
I use 4th Gear 21t 15/42 Sprocket combi 57mm Bore 30mm carb I`m Not On top speed I`more on acceleration because of my road condition on my everyday Rides, always having a back ride , short road, a little bit of traffic , and can use on up hill .... honestly when on up hill I usually use 2nd gear and third gear. for more power ... my 21 4th gear just to assist me on long stretch to have more power and acceleration.
Jackocc
ic, thanks for the info .
Jackocc
based on the orig combi of smx (14 x 38) 14 x 40 or 15 x 42 will be the best sprocket combi for the 5 speed model. 15 x 41 combi best for old sniper (great accelaration and topspeed even if you put 100/80 tires) 15 x 40 ( if your concern is better fuel economy but performs better than stock sprocket)
means LC 135 4 speed need either 15 x 41 or 15 x 40 ??
what if daily ride in penang island , got highway and mount road ridding ?
Jackocc
Hi all sifi, before we change the sporket size do we need to read the original gear box ratio as well ??
if yes, how to calculate it .
for example LC135 4 speed ratio
Gear Ratios
1st: 2.833; 2nd: 1.875; 3rd: 1.353; 4th: 1.045
