Kichi YZ
it won't suffer the top speed? brotry 14t - 42t or 41t bro...![]()
the sprocket comb. 14t-42t or 41t won't suffer the top speed & have an good acceleration?.... bro14/39 sprocket combo + Rextor v.3 + 80 kg. below rider weight...![]()
try asap paps to feel the top speed of ur bikethe sprocket comb. 14t-42t or 41t won't suffer the top speed & have an good acceleration?.... bro
copy bro... i try the top speed of stock sprocket comb. the top speed is 110-115km in my odo-meter....try asap paps to feel the top speed of ur bike![]()
15 42?? all stock engine.. wat is the top speed??? all stock no mods..copy bro... i try the top speed of stock sprocket comb. the top speed is 110-115km in my odo-meter....
ga bisaya kmi dri hw? tan awa b..
how about 14-42t with open pipe only?14t-42t stock snipy..and get a racing cdi + racing clutch spring and you will be happy : ) ride safe
thats right..you just need to try different combination to know the difference and you will know what combination is comfortable for you.I have seen this question over & over.I myself once asked this question as a newbie.IMHO a sprocket size used by someone else most probably won't fit your preference due to factors such as weight, tire size, bore & engine modification, or even the way you ride.Some people suggesting here maybe heavier or lighter than you, have bigger or smaller tires than what you have and they might prefer top end rather than torque..So the real answer to your question boils down to trial & error.There's no way you can achieve what you really need until you try a couple of sprocket combinations until you are satisfied.
your rear sprocket is too big..try 15-42 if you want to improve your topspeed.my weight 100...stock machine.rear 110/80.now using 15-44.good acc bad top speed.how to improve top?
humanbasic In this combi 15/42 you will feel the power of 4th gear.your rear sprocket is too big..try 15-42 if you want to improve your topspeed.![]()
try 15-40 bro...because of your weight you need good acceleration from 1st to 3rd gear..in my snipee i can go 125-130 kph with 15-40 combi..but i am only a 60kgs rider..60/90 frnt 70/90 rear.. 70kgs. rider.. open pipe.. wats da best sprocket combi??good acceleration and can feel the power of 4th gear.. stock combi.. 3rd gear - 105kmh.. 4th gear - 120kmh.. super yuko na.. ma improve ko pa to?
yup, all stock setting papz, about the A/F setting im not sure. My mechanic did some small adjustment that i can't explain here. I did 130kph just once when we went to Mount Samat..that was in Porac i think..2-3km strectch..130? all stock papz?? anu settng ng a/f ? open pipe? anu tire size?
