turbulence
drag race only bro. That will be 25-30km/liter if use for long ridesshould i change my mj to 120?? im using stock bore, faito turbocam and pnp..
im using d stock jettings of d carb.. but my snipee consumes a lot of gas.. what do u suggest bro?drag race only bro. That will be 25-30km/liter if use for long rides
hehe. try 110, 36 bro or 108, 35.im using d stock jettings of d carb.. but my snipee consumes a lot of gas.. what do u suggest bro?
for very tipid gas, yet good accelaration, try keihin 26mm 120, 38im using d stock jettings of d carb.. but my snipee consumes a lot of gas.. what do u suggest bro?
check your sp bro if the color is black or wet black it means your running to rich, what your engine modes... pls. specify... if you using stock bore 120 main jet is big for daily use, you can lower it to 110 to 112im using d stock jettings of d carb.. but my snipee consumes a lot of gas.. what do u suggest bro?
i already stated in page 11.. hehe., anywayz here are the complete details..check your sp bro if the color is black or wet black it means your running to rich, what your engine modes... pls. specify... if you using stock bore 120 main jet is big for daily use, you can lower it to 110 to 112
try mj 110-112i already stated in page 11.. hehe., anywayz here are the complete details..
stockbore
brt cdi
faito clutch spring
r.v spring
faito turbo cams
keihin 28 thailand (using stock jettings and MX manifold)
PNP
15x42 combi
80x80F 90x80R
ill check the sp later and post d pic here..![]()
so with stock bore try a little smaller jettnig
maybe start with 110 main jet and 30 pilot jet
