Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
z_ride13
From its looks..I think it was rich the ground strap and thread should be light in color like a light brown waffle maybe just a little A/F adjustment..counter clockwise (outward) may be 1 turn then remove,clean and install SP again. use your instinct to get the right burn either to adjust to smaller Main Jet.
peepooy
thanks @z_ride13, i will adjust my A/F mixer...
Here's my Spark Plug appearance after rejetting, mj-112 and pj-42... 2 turn counter clockwise...
Positive and Negative comments are welcome... TIA
rolando garra
ill start
Mikuni TM26mm Flatslide on vixion kit
-mainjet #102.5
-pilotjet #30
Mikuni VM26 round carb
stock bore 135cc & stock valves
-mainjet #150
-pilotjet #20
vixion bore 150cc & stock valves
-mainjet #155
-pilotjet #20
Yoshimura TM MJN 26 carburetor
vixion bore kit & bigvalves 18/22
-Main jet #98.8
-Pilot jet #32.5
125cc bore kit & stock valves
-Main jet #95
-Pilot jet #30
sir, ano po yung best daily use setting sa stock carb at stock engine pra medyo mybilis sa overtaking pero less gas consumption tnx po
Sir Traxxas is the best. Thanks for being a certified labrat. You save us a lot of money sir.
[quote="traxxas-modifier, post: 121827, member: 9]ill start
-mainjet #102.5
-pilotjet #30
-mainjet #150
-pilotjet #20
-mainjet #155
-pilotjet #20
-Main jet #98.8
-Pilot jet #32.5
-Main jet #95
-Pilot jet #30[/quote]
UB Sniper
hi bro im using 28mm keihin PE is it ok to start with 115MJ and 35PJ?
its ok bro, as long as your engine runs smooth and fine take also in consideration your needle clip position when tuning your carb just experiment with different settings
suplado010
what is the best jettings po for my
vixion kit
cms cam
stock head (pnp)
oko 28mm round..42pilot 105main po nakakabit ngayon
thanks po sa tutulong saken..
Jessie Y
Hi ,
I use my mc daily as my service to office
Any suggestion on my set up:
62 mm bore
20/22 valves
Air filter - cone type
Faito LOW advance cams
MTRT valve spring
YY Pang pipe
BRT CDI
using 97 octane Sea oil
26 mm Keihin carb (122mj/42pj)
other suggestion
mj - ?
pj - ?
or should I shift to 28mm or 30mm carb
jangbest
Hi there,
62 mm bore
20/22 valves
MTRT valve spring
YY Pang pipe
BRT CDI
other suggestion
mj - ?
pj - ?
Since you are using 62mm Borekit, I think you must use much bigger carb like what you said 28mm or 30mm. Afaik .... and i will taking care of your 26mm carb if you shift.:D:D
Jessie Y
