Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
cr0wer
63mm bore
cms cam
big valve head 19/22
BRT cdi
YZ125 c0il
32mm UMA carb PJ35/MJ102
its my jetting c0rrect???
AJM
@Stockbore thnx sir. your sniper is so fast.. :D i like to be that fast. anw, can you tell me your set up bro? if you dont mind bro . or i can say can i reach 150kph with my current set up? as i have mentioned earlier.
Stockbore
BRT HYPERBAND POWERMAX
LHK CLUTCH SPRING
TDR CLUTCH PLATE
UMA CAMSHAFT
28mm KEIHIN THAILAND
1,2,4, CMS GEAR
BLUE THUNDER COIL
VIXION VALVE SPRING
YYPANG PIPE
PORTED HEAD
14x41 SPROCKET
IRRIDIUM SPARK PLUG
SQUISHED BAND
AJM
LHK CLUTCH SPRING
TDR CLUTCH PLATE
UMA CAMSHAFT
1,2,4, CMS GEAR
BLUE THUNDER COIL
VIXION VALVE SPRING
YYPANG PIPE
PORTED HEAD
14x41 SPROCKET
IRRIDIUM SPARK PLUG
SQUISHED BAND
wow sir bigtym :D sir where did you do the squishbanding? at the bottom or at the top of the cylinder? by how many mm?
mac kevin
my carb is backfiring simultaneously when engine suddenly stop, like a sound of an airgun... what is the cause masters? VM26 mikuni 20pj 150mj on stock engine
