Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
UB Sniper
Sir Question ialng ikot yong air mixture mo, sakin kasi pag naka dalawang ikot na may backfire panaka naka lalo pag pag high rpm tapos bigla mong bibitawan yong throttle don nag babackfire 125MJ/41PJ gamit ko kaya ngayon naka 1-1/2 turn ako gusto ko sana gawing 2 turn kasi iba ang hatak pag naka 2 turn. ito pala setup ko 59mmJVT/big valve 19-22/keihin 28mm/LV cobra pipe.
have you plugged ur AIS already bro? coz usually thats the cause of backfire when using open pipe...
kojack
on vixion kit with stock carb rejet to mj #110 pj #22.5.. my idle seems to go up & down on its own.. has anyone experience this and any tips or solution to this idling problem.. tia
Joe SEVEN
sir,how about my spec is 60mm bore kit,racing cams,tzm carb mikuni 30mm,std exhaust but modify with 26mm manifold,racing coil?
ianghol
i use, cdi brt hypermax, block 62mm, highcam duration, intake and exhaust flow port and polish. exhaust yy pang.
carb keihin PE 28mm, when i twist the throttle a bit, the timing get too high and didn't go down to idle. help !
too rich..try 38/115..1 1/4 from close or 1 1/12 from close:thumbsup:
maybe ur pilot jet is too big..maybe its 40 and up:)
mac kevin
try 155 mainjet use the same type as the stock (longer hexagonal type head) then lower the washer on your needle and check your float level on the carb coz maybe the fuel level is incorrect...
tnx bro..i will also consider this one, my current float height is 24mm after adjusting from stock settings coz its overflowed, i dont know what is the perfect float height of VM26, needle clip is in 2nd from the bottom.
Joe SEVEN
Joe SEVEN
Joe SEVEN
Asuma06
Guys, i don't have my sniper anymore but, I just want to ask if anyone has the experience putting a keihin pe28mm on a fz16 with stock bore??? also what is the best jetting??? :)
Joe SEVEN
mainjet 240,pilotjet 40,im setting the airjet use the high rpm,is good n correct to setting for the highway? my plug is maybe chocolate
UB Sniper
well if your plug looks good and you dont experience problems from ur throttle range then your jettings are fine..
Ginger
kapag pababa nah yung rpm tas pumutok ibig sabihin poh nabibitin ng supply ng gas yung pilot jet...
so ibig sabihin lng nun sir pag pababa na yung rpm mo like nasa 40kph kna nag backfire . at hindi mo maihaboll sa A/F mixture need mag palit ng mas mataas n pj tama po ba?
Joe SEVEN
now I'm setting mainjet 250, pilotjet 40, wind aperture 2.0, 1,2,3 gear is tasty, when in 4 turns so settle, why so so so even plug shows a nice color?
Joe SEVEN
Joe SEVEN
please help me...........................................................................................................
chrisz
currently seeking for the right jettings combi and a/f right mixture..its been almost a week were having trouble in coming up for the right jettings combi for my UMA 28mm carb. heres my set. need an expert advice guys...
vixion kit by (GSD WORKS)
stg2 cams
brt dual band
iridium sp (denso)
Rad airfilter (cone typ) edited
im using UMA carb with i think a mj 108 and pj 30 or 35? would highly appreciate if you can share you experience and the right jettings size with this set up?and do we still need change the needle guys? in this set of jettings i got like (bruk bruk bruk) sounds parang nabubulunan sounds ehhehe.. hope for a fast respones i will try to change jetting after a few hours from now hoping for an advice thnx guys good morning...
SNIPY 135
TRY NOT TO INSTALL AIR FILTER BRO....
MINE WAS UMA 28MM ALSO I BOUGHT IT FROM DRAG RACING SET UP WITH MJ 115 AND PJ 34,
NOW IM USING MJ 108 AND PJ 34 TO MAKE FUEL EFFICIENT FOR EVERYDAY USE....
I'VE TRIED TO INSTALL FILTER BUT IT DIDN'T MATCH, IT FEELS LIKE LACK OF AIR INTAKE ON HI-THROTTLE....
TILL NOW I USE IT AS OPEN CARB....
chrisz
oh yah forgot to add im using rad airfilter the one with a cone type and color red... thanks for the inputs men will try this option .... is you engine loaded too and whats the set up thnx men..
chrisz
how about the carb papi... the dirt and dust will surely get in our carb if no airfilter is in use? did you make some option in terms of that? thnx men...
bro @ronald031803 what can you say about this?...
