Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
kikaipitoy
I don't feel my gas consumption is increased. Better acceleration. Ang bilis ng reaction for 0/kph - 150. My 3rd gear reached 140kph may 4 gear 166 kph. Sprocket comb. 15/39 :D
WOW...monster snipy you have there Sir...care to share your modes Sir? Tnx
sir pls help.
stock bore
uma 28mm carb
brt hpyerbond rcdi
i once used 115 40. it increased power but though once I turned into full throttle it already does have problem.
anyone can help sirs?! :-D
jangbest
sir pls help.
stock bore
uma 28mm carb
brt hpyerbond rcdi
RCDI what is you Valve spring ...
Note : Using RCDI you must also install valve spring or else your engine will explode soon ...
115/40 is too big for your stock bore try to use 110 / 30 ...
CriZden22
Sir i need advice
My engine mods
Vixon block 57mm
Cms cams s2
PNP
CMS valve spring
28mm PE keihin(120-35) current jettings.
What is the best jettings for my carb?
ESOJ de GUZMAN JR
i need also advice. 57mm vixion kit, k1 cam, 28mm keihin roundslide, simota air filter cone type. previous jets. 38-120, a/f between 1/2 and 1/4, the plug is good.replaced due to 30km/l. then change to 38-115 jets, the plug reading is rich. tried a/f 3/4, 1/2,1/4 turns. but still rich. i noticed that when my a/f is 1/2- 3/4 the idle is high and cannot adjust. so return to 1/4. in 1/4 i can adjust my rpm below 1k rpm.
blackknightrealms
What are the best jetting for uma 28 carb 114-40 pj and mj?setup are brt hyperband,spec v cam,vixion valve spring,yy clutch spring, and fz cobra pipe converted to sniper.14x40 combi
cubes
PLS can anyone help to solve the back firing.
may set is-vixion set with ported head
carb-nibbi 26mm round slide the jets are 115/40
before it was 122/45 but still pop sound.
can anyone give info how to adjust the exact a/f mixture?
and how to eliminate the pop sound when already released the trottle?
BTW i already close the AIS pluggin.. can somebody give an advise for this situation.pls help
calling the attention of sir JOB.. :)
pls help...
Gerry Jaloro
pls help...
check your valve clearance...
erhick28
please help how to proper tune uma 28mm carb how many turns. my set 57mm, bigvalve pnp, k1cam, vvspring.. when cruising theres a "pupugakpugak" sorry dont know that in english.. but when in full trottle its good..
Gerry Jaloro
change to bigger pilot jet bro...
Gie
try this sir, from your a/f screw, 3 turn as your base line (from close position), then gradually turn the screw clockwise 2 1/4 turn or more turns and notice the rpm increasing while you turning the screw. you need to reach the highest rpm and try to rev your engine until there's no hesitations (pupugak-pugak). after that spark plug reading... hope it help...
