sir baka modified na mc ni traxxx kaya ganyan ang setting ng a/f
sbi ksi nla sir d2 ng mekaniko ng yamaha ... be faithful dw kng nu gna gamit na gasoline.. bka masira dw f mix ko ang unleaded at xcswaahh sa tingin ko sir stay ka as unleaded sir pero kung may putok try ung vpower ng shell at clean the carb airfilter at check the sparkplug sir
valve clearance??? tune up?tpos paadjust na din valve clearance sir he.he
try ko nga tignan sp ko...cge sir salamat talaga ha....ayy oo pero magspark plug reading ka pa rin sir
cge sir... 4k odo plng po aq.. kala ko di na nid clean carb kasi linis pa naman airfilter eh.. salamat sir.. try ko check bukas sp ah...opo palinis na din ng carb sir maintenance na po
pangit sa MC ang XCS??cge sir... 4k odo plng po aq.. kala ko di na nid clean carb kasi linis pa naman airfilter eh.. salamat sir.. try ko check bukas sp ah...
please share, i need to buy jets for tm28 from him, thanksTRAXXAS: 09174860620anyone here have sir traxxas contact number?please share, i need to buy jets for tm28 from him, thanks
sir traxx may pj 30 at 35 ka pa? pa pm kung meron pa pati price. tiai think on 135cc-150cc using TM28 you should start with pj#17.5 - 20 and mj#185/190/195
paps text mo si admin traxx baka di nakaonline.09174860620.sir traxx may pj 30 at 35 ka pa? pa pm kung meron pa pati price. tia
Air screws all work the same way. Out to allow more air (lean), in for less air (rich). A fuel screw will be opposite. Air screw located on air filter side of slide and fuel screw located on cylinder side(usually underneath).for MIKUNI TM28 users,
can someone please confirm if the the air screw is opposite from keihin's...
if you screw out, mixture will turn out rich... if screw in, mixture will turn out lean... correct?
because on my keihin pe 28 before, it's opposite. if i screw out, the mixture will lean... if the i screw in, rich... at close, engine shuts off.
thanks
