Big carb using modified TPS
makibaoh
paps question lang.
dahil sa na-try nyo na yung ganitong mods,
meron po bang pagkakaiba w/ or w/o TPS,
ramdam po ba ang big difference?
naka bigcarb din kasi ako at gusto ko lang
malaman sana..
gaining knowledge lang po TS..TIA :wink:
rr117-sacker41
makibaohto said:
paps question lang.
malaman sana..
may pagkakaiba paps
kung wala ka TPS malamang umilaw yung red light sa panel board mo at kung may TPS ka nga pero naka steady nman ang sensor ng TPS iilaw pa din ang red light (d ko alam kung papano ginagawa ng iba para d umilaw ang red light sa panel board)
information came from medichloreans:
PS (Throttle Position Sensor)
TPS (Throttle Position Sensor)
Features of the technology
A throttle position sensor (TPS) has been adopted on the T135 to enable ignition timing control utilizing a 3-D program map based on signals on engine rpm and throttle opening.
Effect (User Benefits)
(1) Outstanding fuel consumption characteristics - Optimum ignition timing in accordance with actual running conditions contributes to excellent fuel economy.
(2) Excellent drivability - The optimized ignition timing means that there is more efficient burning of the fuel droplets in the combustion chamber, which in turn contributes to improved drivability.
