1. Performance (Acceleration, Topspeed)shutdown said:CALLING FOR ALL SNIPER MASTERS.
OKO, UMA, MIKUNI, KEIHIN
2. Fuel Consumption
PLEASE RESPOND. NEED SERIOUS HELP.
you should reach up to 150kph on ur current setup if ur using 28mm or 30mm carb size..shutdown said:@the_one, thanks for the response.
SETUP:
Vixion57mm bore, Vixion cam & valve spring
Rextor RCDI
Protec Racing Ignition Coil
Denso Iridium Sparkplug
AHM pipe
15:39 sprocket, 90/80 rear & 80/80 front tires
Current Topspeed: 130-135kph only on normal riding position
CONFUSED on what carb type and size to buy.
WANT to reach 140kph on normal riding position
hearthrob16 said:UMA 28 is much expensive than keihin dude...uma 28 costs 4500..
keihin PWK 28mm costs 10k above,..and the KEIHIN cr flat costs 30k...
try to PM haen for the keihin PWK..
Keihin Thailand - less budget less headached heheheclearhearts said:@hearthrob bro wat kind of keihin u r using. i plan to get one.
@the_one wat do u advise bro
keihin PE 28mm..clearhearts said:@hearthrob bro wat kind of keihin u r using. i plan to get one.
