is this possible even if it's new piston/rings & block?Blue smoke - Oil burning (i.e. Piston ring)
White smoke - Water Burning "Steam (i.e.Head Gasket )
Black Smoke - Rich mixture/unburnt fuel (Ignition,A/F Mixture and etc.)
Red Smoke - Ghost Rider Mode![]()
yes Sir. Below are the reasonis this possible even if it's new piston/rings & block?
sounds like either a piston ring or valve seal problem sirI'm getting confused,sorry newbie here with regards to our engine....mine is,the white smoke will come out only when I rev not really a full throttle (e.g. overtaking another vehicle)...btw my snipey is all stock (engine & pipe).
hmm for the AIS I disabled it long time ago sir, your number 1 post makes me think, i'm guilty on improper break in... maybe i need to change piston & rings and see..yes Sir. Below are the reason
1.) Defective/improperly installed new piston, piston rings and engine block - improper break in, prolonged high RPM on break in period, using synthetic oil on break in (Glazing of Engine Oil in the walls), poor quality piston, piston ring and block.
2.) Oil leaking past the exhaust valves - true for system with AIS if AIS is contaminated with oil through the Air Filter.
One scenario for your sir is this...
You experienced blue smoke, oil seeped in the AIS and Air Filter, you replaced your Engine (Block, Piston and Ring) but you didn't clean the AIS and AIR Filter system causing the blue smoke.
Hope that helps. All this experience is from 10 years in Car Tuning. Dont trust your mechanic immediately without diagnosis. A well maintained Sniper can run 100K kilometers without consuming oil.
