plug n playPlug n play na lang po ba ung k1 or mag valve pocket pa?
racing cdi sir,valve springs at open pipe..btw ilan po top speed mo sir nung nagpalit ka ng cams??Sakto po naka 26mm oko ako pasok na pasok lakas ng hatak kaso walang dulo ngaun naka stock po lahat anu pa kaya pede idagdag mga ser ung hnd magagalaw ung engine![]()
kaya naman talaga pero long stretch yanHnd pa po ako ng cams ser so far kaya niang tumakbo ng 130kph![]()
130 kph???para sakin matulin na yan..Hnd pa po ako ng cams ser so far kaya niang tumakbo ng 130kph![]()
takot na nga ako sa 120kph ng all stock mx ko eh..
baka ma 1 time..ride safe po lagi..
how about if i change my ignition but stay stock cdi? will it boost a little bit?sir before changing your cam it is advisable to first upgrade your ignition system..with ignition limit of 9.5k on stock cdi will make your racing cam useless...when changing cam also change your valve spring..specv racing cam is cheap for 1400..very durable...s2 stage for stock pipe and s1 for more agressive set up and performance...
sir surely it will make a difference if you mean changing a more powerful ignition coil...but changing rcdi will remove your limiter and add more noticeable power increase than changing only ign coil...changing both is better..how about if i change my ignition but stay stock cdi? will it boost a little bit?
