can i bought this things in malaysia?
darkkey
rudduan said:
darkkey said:
rudduan said:
here's the link http://www.flickr.com/photos/23660320@N ... otostream/
hope all of u guys enjoy it....
Bro just wanted to know. If using this hugger dont you feel the bike jerks when riding with heavy pillions? I tried riding heavy pillions and it causes my bike to jerk. Dont know if its normal for Mono suspension bikes.
absolutely no,with my modification i dont feel any jerk,coz it have lots of free-play gap
:cry: Too bad my weight is around 80 and when I carry someone with like 70 my bike jerks when riding slow. Anything could be done to prevent this. Between, I have not installed any rear hugger and my Mono are stock one.
darkkey
rudduan said:
hey im fat,i did it,no worries bout the jerk,i think its just your imagination
Well this jerk actually happens when you rev down or change to lower gear. I dont know if its my imagination. I've asked my other friends who ride my bike and they too tell me the same thing. Anyone having similar case like me. Is it that my Mono is spoilt? Between, I just bought the bike 5 months ago milleage 6+++KM.
goff_d_p
hey darkkey, i had that problem with my bike all the time for the first 1k klm,it's when your riding, and you release the throttle a little, and the bike lunges forward, i just keeped playing around with adjusting the air fuel mixture. do you know how to re-set the air fuel mix screw?
anyways i finally got a three turn on A/F with my race air filter and no more jerk. you just need to keep playing with it, i think it's part of a break in thing.
my cousin says it's a little bit of fuel left in the carb, and the TPS reads that amount being there, so to burn it off it does that lunging affect. just keep playing with the A/F adjustment, re-set it, then adjust to different setting.
you don't have to remove any covers, if you don't know how to reset it, clockwise all the way till it stops, put a mark on the screw driver and on the side cover, then turn counter clock wise for two full turns, try that, if that doesn't work, the re-set, and try 2 1/4, then 2 1/2 or 2 3/4 turns, everyones bike is different. the most common is 2 1/2 turn.
darkkey
Thanks for your advice bro but I dont know how to re-set the air fuel mix screw. I it the one they use to set the engine timing?
goff_d_p
no, just the air / fuel. don't touch the throttle
the throttle is the idle adjustment.
just turn the one in YELLOW clock wise all the way till it stops, then mark the side plastic eather with a white board marker or just put a nick on the edge of the opening, then watch the screw driver mark as you turn it counter clock wise 2 1/2 full turns. then take it out for a drive.
also, check the gap of your spark plug when you do your next oil change. change the plug to eather NGK or a DENSO irudium plug, but make the gap .8. that will help with power too.
darkkey
Will surely try out today on the air mix screw. I just changed my sparkplug three weeks ago. Changed to NGK Platinum G-Power. Wanted to change to Denso Iridium but no stock available here at the moment.
hyattousai
hey all...
u all say about hugger isnt?
i agree with some people here told that 125z hugger is more cheaper...
4 me, i didnt do much for renovate the hugger...
juz tie the hugger with chain cover and 4or me, its still nice....
please refer to my own bike and ur comments is welcome.... :oops:
darkkey
Thanks bro Goff for your suggestions. I tried as per your advice and found my ride to be more smooth and no more jerking. Thanks a lot again bro for your advice.
