Its Not safe just change RCDI alone, you must also change your valve spring.Good day! is it safe just to change rcdi with stock? and what brand of CDI will i buy thanks for the feed back!
why? Stock CDI has Limiter and RCDI has no limiter limiter on stock CDI serve as a safety purpose to our engine to avoid over rev, and stock Valve spring can handle only 900rpm while racing valve spring like vixion brand can handle upto 1200 rpm AFAIK.
good read sir.. so i should say i will buy RCDI + VALVE SPRINGIts Not safe just change RCDI alone, you must also change your valve spring.
good read sir.. so i should say i will buy RCDI + VALVE SPRING![]()
Sir jangbest is it necessary or optional to change also our cams?Its Not safe just change RCDI alone, you must also change your valve spring.
Not necessary its just an option "ika nga para isang bukasan na lang" ...Sir jangbest is it necessary or optional to change also our cams?
Sir what brand can you recommend for valve springs and rcdi?the better one if possible..Not necessary its just an option "ika nga para isang bukasan na lang" ...
and yes you can use your stock pipe on this mods.
vixion valve spring would be the bestSir what brand can you recommend for valve springs and rcdi?the better one if possible..
How about rcdi brand sir?vixion valve spring would be the best
Dami choices ng brand of RCDi. Right, jangbest ?Good day! is it safe just to change rcdi with stock? and what brand of CDI will i buy thanks for the feed back!
What kind of security purposes sir?i think i will buy pitzbike cdibecause there is a video on how to use and it has security purposes
Yes paps dami tayo choicesDami choices ng brand of RCDi. Right, jangbest ?![]()
Vixion valve spring tried and testedSir what brand can you recommend for valve springs and rcdi?the better one if possible..
Price range for this sir how much?Vixion valve spring tried and tested
What would be your choice sir?based on your experienced.Yes paps dami tayo choices
Rextor CDI
BRT
IMC
Pitsbike
Its you to decide![]()
I use BRT Dual band for more than 2 years and still kicking, definitely BRT brand i would suggest.What would be your choice sir?based on your experienced.
