cdi: rextor or brt
johzz
pag nag cams ka nalang sabay mo yung valve spring.
ok lang yan rcdi at stock valve spring. basta wag over rev.
nd ka matutukuran valve.
safe yan.
corgph666
thank you sir!!! atleast ngaun.... hindi na ako esep esep!!!! buti nalang hindi ako gigil sa pag piga..... hehehe salamat po master... thanks sa info..
GOD bless!!
corgph666
@unggoymonkey - ask ko lang naman sir kung ok lang un for everyday use.... even naka rcdi.....kasi stock pa nga gamit ko sir.... then im planning din naman mag change ng valve spring at cams... etc... kulang pa budget!!!
kailangan ba mag over rev para masagad ang RPM?? hehehe
thnks god bless......
axon
TS
budget tip try put some washer before the valve spring to make the spring more stiffer than stock you can notice the lil' changes, imho your rcdi is useless without upgrading a valve spring its just a bit better from your stock, and you don't need to over your engine before each gear, specially if your bike is not in the race , instead just watch you speedometer,
corgph666
@axon - salamat po sir sa info... godbless
I already change the stock valve spring to rvalve spring even the clutch spring..... medyo nahirapan lang mag hanap ng marunong na mekaniko dito sa lugar namin....katakot kasi pakalikot eh ^^ hehehe, sa ngaun ok naman po hindi ko pa lang natesting sa long drive.... hehehe
thanks to all "merry christmas po" hehehe
josam07
Rlopez said:
me too BRT hyperband user here coz im not into racing just for everyday use and to avoid problems sir wingman advice me to buy that ^_^ ngayon ok na ok ang performance ng motor ko hehehe dati 100 topspeed ko now tumataas pa so far nakaka 110 na me eh mabigat ako 95kgs. Ok din naman daw po ang rextor redmamaw
yahh wer same...BRT hyperband user too..my topspeed from 120 to 130..my weigh is 75kgs. :D
j_caldeojr
Mga master plano ko rin magpalit ng Rcdi rextor or brt i just wanna know kung kailangan pa rin po bang magpalit ng valve spring para iwas valve float at tukod tama po ba??
Thanks po
JhayBoo
+1000 ako kay Sir Axon
up for this one!!!
keep safe guys... watch mode muna ako sa ngyn..enjoying my stock settings..
thopiang
vindeath07 said:
panu ko po mainstall tong BRD dualband??... O_O any help po mga master..
plug and play lang yan sir, tanggalin mo yung dalawang socket sa stock cdi then plug it to ur brt, vroooommmm
turok
IM USING THE BRT NEO HYPERBAND GREEN, AND AFTER NINE MONTHS I THINK ITS BROKEN.??
IT SHOULD HAVE NO LIMIT RIGHT??
BAD TRIP..
PERO IM NOT SURE KUNG SA RCDI NGA KC NAG PA LAGAY AKO NG VALVE SPRING TAPOS PORT AND POLISH. AFTER THAT UN BUMABA UNG LIMIT HANGANG 40KPH NALANG UNG 1ST GEAR KO 70KPH SA 2ND GEAR..
CAN SOMEONE GIVE ME A CLUE ABOUT WHAT HAPPENED....
anex
hi guys, anyone here help me. i've got the BRT imax 24 steps so i don't know how to set up exactly the map for my bike. help me please...thanks...
