clutch lining?clucth spring?valve spring???
chrisz
hello po sa laht mabagal napo humatak ung snipee ko lalo na pag nag chachnge gear ako..tama po ba yung mga above mentiin ko na dapat palitan?if meron po kau ma susugest plsss paki msg nman po ako..at plss paki naman po yung mga brand at price maraming thnx po
Paladin
If you use stock cams, it's just okay not to change valve spring anymore. I guess your clutch are already sliding why your bike has decreased on pick up. try faito clutch spring and Faito swift-z clutch plate. Or if you have extra cash get Faito Thunder clutch plate.
chrisz
thnx for the advice sir....can i ask also where to buy it here in caloocan if you know a shop here that offer original faito items and how much it would cost thnx in advance sir
Paladin
I have a trusted seller in 10th Ave. Kindly PM me for details. His prices are very much competitive.
macoolet
try to replace it with genuine yamaha sniper clutch lining and clutch plate specially if it is for daily use and not for racing...stock valve springs and clutch springs to be retained not unless if the stock clutch spring looses it's stiffness..it's your choice to replace it with an aftermarket springs or still stock springs...for my recommendation it would just be CRG clutch springs or OEM clutch springs for daily use...;)
JhayBoo
can you please enlighten me Sir.... what is clutch spring for?! :)
vanjo03
im using FCCI clutch lining and namban clutch spring so far so good and the price of FCCI is not that expensive :D
